Portable software question
Hi
I have tried surfing internet to explore my knowledge about making portable software and as a consequence I have done the portable one. nut the problem was HOW ABOUT IF I AM GOING TO MAKE PORTABLE AUTODESK REVIT STRUCTURE 2010 AND AUTODESK ROBOT STRUCUTRAL ANALYSIS, we know that it perfectly works via Revit Extensions do I need also to make the extension portable or there is no remedy for that?
thanks again
hi
i think that you cannot make the extentions portable. just install them with the software and make it portable in the same session
regards
the software posted links sould be used for evaluation and testing purposes, if you like it buy it !! Always read the disclaimer and act acoordly
Have you tried making that option?
hi
yes, after your post i created Revit Structure + extentions but its a very huge file
2.8 Gb
and also Autodesk Structural Analysis 700 Mb
i will try to ulpoad to rapidshare but will take some time my connections is slow
regrds
[-] The following 2 users say Thank You to mig21 for this post:
  • faros3000, 02410021
