Math Mechanixs 1.4.0.4
Math Mechanixs is a versatile and powerful mathematical analysis tool. Math Mechanixs is as easy to use as a common calculator is and may be used by high school students, college students, engineers and scientists.
Math Mechanixs does not work like a conventional calculator. Math Mechanixs understands the mathematical language as opposed to a calculator, which only understands keystrokes on the buttons. Because Math Mechanixs is capable of understanding the language of mathematics, you can communicate with Math Mechanixs simply by typing a mathematical expression into the Math Editor the way that you would write it on a sheet of paper. This allows you to describe the problem using words in addition to solving the problem mathematically. After you have completed the problem you can save it to a file and send the file to a printer.
The Function Library also includes a unique feature designed to provide a convenient graphical user interface (GUI) for solving any defined function. This utility is called the Function Solver. The function solver works with any predefined or embedded function including user defined functions.
This software works 30 day in Evaluation Mode and after 30 days in Evaluation Lite Mode.
Moving the clock forward before installation will add the same time interval.
In case you forgot to do that use regedit and delete the folowing keys:
HKEY_USERS\S-1-5-21-448539723-606747145-682003330-1003\Software\Classes\CLSID\{54260BAE-A68E-4CF3-8FD5-87D20CF85A20}
HKEY_USERS\S-1-5-21-448539723-606747145-682003330-1003\Software\Classes\CLSID\{961F6A10-E84C-44FA-AA3A-D0D471268694}
[Image: 34312967056945733258.gif]
[Image: 07848594571091666483.gif]
  • zrilek, bybyby
Thanks to bybyby for the remark he sent me.
The first part of the string is different in every computer. The string to search is in HKEY_USERS but the only common is for the two keys the last part after CLSID. Search for {542.....} and for {961....}
