12-29-2009, 12:54 PM
There is a (simple) way to convert extension DJVU in to PDF but if you do so in some cases PDF e-book will be a bit or "few times a bit" larger than DJVU format.
To convert DJVU in to PDF I use IrfanView program. Just open DJVU file using IrfanView and go File -- > Save as and from the list Save file as select PDF - Portable Document Format, click Save, wait few seconds and this is it...
Here are two links where you can find IrfanView program:
Hope it helps.
Best regards.
G
Hope it helps.
Best regards.
G
