Finite Element Modeling of Partially Restrained Beam-to-Girder Connections
[Image: 23678827430763656392.jpg]
In recent years the design of steel framed composite floor systems has been controlled more often by serviceability criteria than by strength. It has been suggested that a partially continuous composite floor system would improve serviceability limit states; and that, partially restrained beam-to-girder connections are the key to such a floor system (Rex and Easterling 1994). A research project aimed at developing design methods and criteria for partially restrained beam-to-girder connections and partially continuous floor systems is currently in progress at Virginia Polytechnic Institute and State University (VPI). This paper focuses on a finite element modeling technique that is being used to predict the moment-rotation behavior of various beam-to-girder connections. This method relies heavily on the behavior models of various connection sub-elements (bolts, welds, etc...). These connection sub-element models are also discussed.
Edit reason: Dead link removed. Title of thread adjusted to fit the title of article (G)
[-] The following 5 users say Thank You to preceptor for this post:
  • zrilek, mad_world, soringer, Slide Zone, Haseeb Jamal
Mirror links (my upload):
Article can be found in the book Connections in steel structures 3 as well. The book is posted here:
[-] The following 8 users say Thank You to Grunf for this post:
  • Dell_Brett, kowheng, baikur, zrilek, rohailiyaz, mad_world, civilteam, jcbv
ConPrimer-2 Finite Element emmi 0 1,778 03-27-2015, 01:59 AM
Last Post: emmi
Dynamic Finite-Element Analysis of Jointed Concrete Pavements TAFATNEB 0 1,129 03-31-2014, 11:46 PM
III - 1 FINITE ELEMENT ANALYSIS OF CONFINED CONCRETE COLUMNS TAFATNEB 0 1,323 03-31-2014, 11:11 PM
A Framework for 3D Finite Element Analysis of Lateral Pile System Response asim99 0 1,339 04-27-2013, 10:53 PM
Last Post: asim99
A necessary modification for the finite element analysis of cracked members detection asim99 0 1,307 04-25-2013, 12:56 AM
Last Post: asim99
