12-16-2009, 05:56 AM
(This post was last modified: 12-01-2011, 04:48 PM by usman. Edit Reason: )
PCA - Slab Thickness Design for Industrial Concrete Floors on Grade
DESIGN OF GRADE SLAB FOR CSB
The Grade Slab is designed using Portland Cement Association (PCA ) method.
BASIC DATA
Grade of Concrete
Grade of Steel
Type of Sub-base below the Slab (SAND)
Length of the slab between ends
PDF File ll 14 Sheets ll From On Going Project.
Vinu...
"A Smallest Good Deed Is Bigger Than Greatest Good Intention".
The following 47 users say Thank You to vinnunsam for this post:47 users say Thank You to vinnunsam for this post
• rendel_©, michaelsoe, subin91, lucky_b2me, Dell_Brett, vvvv, oanm2000, henrycv, riprap, jaks, tgbyhn1234, rohailiyaz, jcoronellr, lesgiu, zego2000, Haseeb Jamal, ruaumoko, Yasir, m_mostafa14, HASH007, joradu, jbahari, civilteam, jf28, Ernest0, rakaonly, SUSheikh, eshetu, lasalleguy, oram, madzaz, axcel, gatob, dinu69in, s_narucha, zrilek, cowboy, uzi123, tonmjr, batata666, sodapas, er.shyams, Quantumm, nickycruz, we_mbm, ykhackhack, chicosi
04-04-2012, 05:19 PM
(This post was last modified: 04-04-2012, 05:32 PM by designer2000. Edit Reason: )
MIRROR
[/quote]
The following 15 users say Thank You to designer2000 for this post:15 users say Thank You to designer2000 for this post
• chrono146, gulilero, kowheng, knrsa, ting tsai huang, Dell_Brett, sodapas, er.shyams, shanta, Quantumm, YeiYei, SCREAM7890, nickycruz, chenamoy, ykhackhack
Hi
Here is new link
The following 13 users say Thank You to Jackass for this post:13 users say Thank You to Jackass for this post
• blaze, gulilero, Dell_Brett, Andrew seah, pedzaquino, malc, smrutigandh.42, ykhackhack, ingchio, cristi, EugeneV, cosmic_fighter, harsono
Author(s)/Editor(s): PCA | Size: 1 MB | Format: PDF | Quality: Unspecified
The following 18 users say Thank You to inge911 for this post:18 users say Thank You to inge911 for this post
• gulilero, oanm2000, Andrew seah, Dell_Brett, PinkPant, blaze, kurt_dabs, anfaga, ting tsai huang, psk62, ykhackhack, Trishu999, f_slikken, harsono, sacem, civilgen, jayborre, narendra
