Concrete: P M Interaction curve
P(N) M INTERACTION CURVE DIAGRAM
[Image: 08410327300192985734.jpg]
ABSTRACT
The limit state design procedure of reinforced concrete elements has undergone major revision by most of the
international codes in recent times in accordance to the performance based engineering approach. A thorough
understanding of axial force-bending moment (P-M) yield interaction of RC elements is necessary to perform a
satisfactory design catering to displacement demands particularly when the structure is subjected to seismic loads.
WARNING:
THIS SPREADSHEET FOR REINFORCED CONCRETE SECTION
YOU MUSTN'T USING FOR STEEL SECTION
urbana
screenshots:
[Image: 26836823268811148844.jpg]
[Image: 64404171251389774173.gif]
.xls   INTERACTION CURVES.xls (Size: 23 KB / Downloads: 469)
[-] The following 23 users say Thank You to preceptor for this post:
  • kowheng, engr1900, oram, Dell_Brett, super_engineer, jcoronellr, chicosi, nuttapolk, zrilek, gabriel, wa_sin_29, pmav99, subin91, andtangh, soringer, mad_world, đầuto, ehsan, Mhasan, zainseiya, arceon, Alexander, lucky_b2me
Dear Urbana,
Refer to formula in column N(kn), could you please explain more, where the number 850 come from?
Thank you.
Dear kowheng
firstly; you can say that N(kn)=P(kn)
Secondly
i entered below expression
N=0.85Fcdab+As/2(So+Su)+AmSm
M=0.85Fcdab(h-a)/2+As/4(So_Su)(d-d')
Reinforced concrete c30 (fcd=20Mpa ,k1=0.82)
steel s420 (fyd=365 Mpa)
you can see above that tension's unit Mpa
in order that convert the expressions,i multiplied 10^3
i hope ,i explained that
regrds
urbana
[-] The following 3 users say Thank You to preceptor for this post:
  • kowheng, soringer, mad_world
Bi-axial Interaction Curve ACI camto2 0 1,665 07-14-2018, 05:23 PM
Last Post: camto2
Interaction Curve mono-axial to ACI camto2 0 722 06-09-2018, 05:53 PM
Last Post: camto2
