| RetainWall V2.00 Current time: 05-20-2012, 11:05 AM |
RetainWall V2.00
02-21-2009, 04:08 AM
(This post was last modified: 12-11-2010 03:17 PM by kowheng. Edit Reason: )
Post: #1
RetainWall V2.00
RetainWall is a software mainly designed for the purpose of designing a concrete or masonry retaining wall. The wall may retain soil or other granular material. It analyses the stability of the wall based on the loads and the resulting base pressure, sliding, eccentricities and restraints. Loads applied on the wall may consist of self weight, soil pressure, water pressure, live and seismic loads. Sliding restraints may consist of passive earth pressure, other structures or a shear key. If the wall is a reinforced concrete structure, the software also supports the reinforcement design. In addition, a soil pressure calculator is also provided. RetainWall is designed to be an easy application, on-screen trial-and-error method and quick solution finding of the design. A familiar designer can design the wall within minutes. Complete outputs can be viewed on screen or printed. Operation of the software begins from the initial dimensioning of the wall, earth surface and water levels by clicking on the given dimensions. Next is inputting material properties of the wall, soil, water and reinforcement bars. External loads given consist of live load on the ground surface, seismic load as a horizontal seismic coefficient and any concentrated loads if required. Results of the wall stability can be obtained immediately. If they are not satisfied then another trial can be made very quickly. There are also options to use or not to use water, seismic or a shear key. You have the possibility to print your final results. Using the internal forces of the wall, reinforced concrete design can also be done very quickly. It requires only bar diameters and spacings of the reinforcements. RetainWall supports metric, SI and British unit systems *************Structural Engineer |
The following 16 users say Thanks/Agree You to mohcivil for this post:Dell_Brett, Dell_Brett, tifosi84, tifosi84, reynand_d, reynand_d, junaid, junaid, YaqubMughal, YaqubMughal, thinhdq2005, thinhdq2005, tachuelo, rezart, DamaD, rkce |
12-11-2010, 03:24 PM
(This post was last modified: 02-07-2012 10:41 AM by Dell_Brett. Edit Reason: )
Post: #2
RE: RetainWall V2.00
New Links: RetainWall V2.00
![]() *************New Links: RetainWall V2.00 (portable) ![]() ************* |
The following 20 users say Thanks/Agree You to kowheng for this post:Diquan, blaze, malc, Petrit, Dell_Brett, utan, Finna, robertsas, |
12-11-2010, 05:40 PM
(This post was last modified: 02-07-2012 10:43 AM by Dell_Brett. Edit Reason: )
Post: #3
Links to Retaining Wall v2.0 Portable only:
![]() ![]() (image for reference only - The file version is 2.0) ************* |
The following 48 users say Thanks/Agree You to Dell_Brett for this post:kowheng, shpatone, oanm2000, fnoto, simanta, Rainbow, Finna, robertsas, |
08-16-2011, 11:13 PM
Post: #4
NEW HOTFILE MIRROR
*************No limits to creativity My body may be broken , but my spirit still fights on freedom |
The following 6 users say Thanks/Agree You to joker™ for this post:zimmermannn, Dell_Brett, cigutierrezg, IDXaydung, moulawain, hadeest |
08-22-2011, 07:45 AM
(This post was last modified: 02-07-2012 11:47 AM by Grunf. Edit Reason: )
Post: #5
Link for RetainWall V2.00 (not portable version):
*************Software/Book in the links of this post is for evaluational and testing purposes, you must not use it for any commercial purpose!! If you benefit from using this Software/Book, you have to buy a licence!! |
The following 6 users say Thanks/Agree You to vsa2010 for this post:kowheng, nhim4mat2006, odiclas, Dell_Brett, ting tsai huang, Yuma |
08-22-2011, 08:44 AM
(This post was last modified: 09-30-2011 11:06 AM by kowheng. Edit Reason: )
Post: #6
Mirror Links: RetainWall V2.00 (not portable version)
RAR 2.4 MB ************* |
The following 15 users say Thanks/Agree You to kowheng for this post:Dell_Brett, araza023, ebaturalp, rkce, cordoba123, oreslaw, warbeast, wanazri, malc, danny045, blaze, Ivan_1980, maijuji, hernansgz, TurboXUser |
02-07-2012, 07:02 AM
(This post was last modified: 02-07-2012 08:55 AM by BennyP. Edit Reason: )
Post: #7
here this is active!
The following 9 users say Thanks/Agree You to Katracho for this post:Dell_Brett, Grunf, albani, narendra, tuanpecc1, ykhackhack, zego2000, draluka, TurboXUser |
User(s) browsing this thread: 1 Guest(s)
View a Printable Version
Send this Thread to a Friend
Subscribe to this thread
![[-]](http://netdna.civilea.com/images/CivilEAV3.0/collapse.gif)
![[Image: 01688764638890126346.jpg]](http://pic.civilea.com/images/01688764638890126346.jpg)
![[Image: 03888489104082721696.jpg]](http://pic.civilea.com/images/03888489104082721696.jpg)
