Tuneup Utilities 2010
TuneUp Utilities 2010 v9.0.2000.16
[Image: o0uq5rwmsis1y2bz5689_thumb.png]
The complete tuning solution for your PC
With TuneUp Utilities, your system will be faster, more comfortable and more secure. All important aspects of system configuration, security, cleanup and maintenance can be accessed through a modern graphical interface.
TuneUp Utilities will optimize the performance of your PC, solve problems and help you easily customize your computer to suit your needs.
TuneUp Utilities helps both beginners and experts to make Windows meet their needs in a way that is better, easier and safer. All important system options are explained in an easy way and can be turned on or off at the click of your mouse. TuneUp Utilities will then make the necessary changes in the registry or boot files automatically. We place a high value on system stability, so that Windows won't stop working reliably. And most changes that you make can be undone in TuneUp Rescue Center - easily and safely.
TuneUp Utilities also gives you many more options. In addition to helping you make Windows "better looking", you can also clean up and optimize your system at the click of a mouse. TuneUp Utilities 2010 will clean up unnecessary data from your hard disk and remove unnecessary entries from your registry. It can defragment your hard disk and registry and optimize your system settings to make Windows run substantially faster. Most of this maintenance is performed automatically every week by TuneUp 1-Click Maintenance.
Automatic adaptation to your operating system
When making these changes, TuneUp Utilities reaches deep into the Windows system. However, Windows has changed a great deal from version to version. Because of this, the software automatically recognizes and adapts to each supported version of Windows. This is done automatically so that you, the user, won't have to re-learn the software for each operating system version.
Download Links:
[-] The following 12 users say Thank You to W31Andrew for this post:
  • Grunf, engr1900, blackjack, surajdas, kaungthant, bakoz, u4406014, erimajus, isurya, paulocs, julioreptil, ykhackhack
Serial Number provided is now blacklisted, warning now appears advising number no longer valid
(02-22-2010, 02:42 PM)BigD Wrote: Serial Number provided is now blacklisted, warning now appears advising number no longer valid
Active key:
Organisation: A
Serial: N1YD6Q-6JP6QP-2JN2MH-05JJVV-M3Q5T3-APTWNR
Cheers!
[-] The following 4 users say Thank You to tuanpecc1 for this post:
  • Grunf, julioreptil, ruaumoko, ykhackhack
the link is too slow to download, pl. provide another link.
(04-26-2010, 03:48 AM)napeera Wrote: the link is too slow to download, pl. provide another link.
Mirror link:
[-] The following 6 users say Thank You to tuanpecc1 for this post:
  • napeera, dbsimon29, lednar_ved, ruaumoko, u4406014, ykhackhack
TuneUp Utilities 2012 v12.0.2110.9 kvtasp 4 3,409 06-28-2013, 05:23 PM
Last Post: azas
Paragon System Upgrade Utilities 2010 BennyP 0 1,624 07-17-2010, 02:12 PM
TuneUp Utilities Grunf 0 1,544 06-17-2009, 07:11 AM
Last Post: Grunf
