Civil Engineering Association eBooks Water & Hydraulic Engineering Manual on Scour at Bridges and Other Hydraulic Structures (CIRIA)
 febo927
User ID: 23688
Threads: 105
Likes: 4,179 in 339 posts
Given Likes: 1279
Points:17,883 EP
09-14-2018, 12:52 PM
Author(s)/Editor(s): R. May , J. C. Ackers , A. Kirby | Size: 16 MB | Format: PDF | Quality: Scanner | Publisher: Construction Industry Research & Information Association (CIRIA) | Year: 2002 | pages: 226 | ISBN: 0860175510 / 978-0860175513
[Image: 19385862757695587537.jpg]
Structures built in or near rivers and other channels can be vulnerable to scour around their foundations. If the depth of the scour becomes significant, the stability of the foundations may be endangered, with a consequent risk of damage or failure of the structure. In the past 15 years, there have been several bridge failures, resulting in transport disruption, economic loss and, on occasion, loss of life. Some of these failures are included in the manual's summary case studies. The factors influencing scour are complex and vary according to the type of structure. Protection works for preventing scour need to be designed to withstand the flow forces imposed on them and have to be practicable to build and install, while minimising adverse environmental effects. The manual therefore considers scour processes, estimating and assessing scour, protective measures, monitoring, environmental factors, risk assessments, and cost and benefit analyses. This manual is intended for engineers engaged in the design, construction, operation and maintenance of structures in the water environment that may be subject to scour of erodible beds or banks. It is equally relevant to UK and worldwide scour problems, and to new as well as existing structures.
[-] The following 13 users Like febo927's post:13 users Like febo927's post
  • blaze, zrilek, Aviator, Nita1391, malc, PinkPant, gulilero, munycamsec, Dell_Brett, cace-01, oanm2000, kowheng, spat
  Flow Transition Design in Hydraulic Structures Dobblo 2 2,960 05-23-2020, 08:39 PM
Last Post: Veggeta
  Irrigation Engineering & Hydraulic Structures ska51 1 3,991 11-16-2016, 11:41 AM
Last Post: ska51
  Hydraulic Structures: Sheng-Hong Chen emmi 2 1,894 10-07-2015, 03:56 PM
Last Post: ibg0203
  Dams and Appurtenant Hydraulic Structures cace-01 1 1,865 08-30-2014, 12:39 PM
Last Post: PinkPant
  Piers, Jetties and Related Structures Exposed to Waves: Guidelines for Hydraulic Load i_kabir 2 2,027 08-24-2014, 04:52 AM
Last Post: odiclas
  Hydraulic Structures: P. Novak babak 8 5,063 10-16-2013, 01:20 PM
Last Post: axcel
  Bridge Design Manual-Hydraulic Design arshiakh 0 1,220 03-01-2013, 02:45 PM
Last Post: arshiakh
