CSI ETABS V17
CSI ETABS v17.0.0
[Image: 60978758605635764552.jpg]
New Features:
- General quadrilateral meshing of floor areas.
- User-defined internal mesh for shells.
- Improved merging of floor areas by removing common edges.
- Ability to automatically add rigid-zone areas over columns and walls.
- Improved DirectX Display.
- New link property to represent high-damping rubber-bearing isolator.
- Multiple controlled displacements for static pushover analysis.
- Link properties can be used for line and area springs.
- Strain response for shell objects (walls and floors).
- Option to control the slope of steep strength-drop in frame hinges.
- Improved convergence behavior for displacement-controlled nonlinear static load cases.
- Non-iterative event-to-event option for nonlinear static analysis.
- Increased speed and reduced storage for running and displaying results of nonlinear load cases.
- ASCE 41-17 auto hinges.
- Optional points BC and CD on hinge backbone curves.
- Auto-wind loading according to the ASCE 7-16 code and Korean Building Code (KBC 2016) added.
- Auto-seismic loading according to the ASCE 7-16 code, Korean Building Code (KBC 2016), Indian Standard Code (IS 1893:2016) and Turkish Seismic Code (TSC-2018) added.
- Automated response spectrum functions according to the ASCE 7-16, Korean Building Code (KBC 2016), Indian Standard (IS 1893:2016) and Turkish Seismic Code (TSC-2018) added.
- AISC 360-16 composite beam design added.
- AISC 360-16 steel frame design added.
- NTC 2018 Steel Frame Design added.
- IS 456:2000 concrete frame design updated for the IS 13920:2016 seismic code.
- Parallel processing has been implemented for running design (all types).
- Automatic concrete column design to achieve strong-column/weak-beam connections.
- Implementation of AISC Design Guide (DG) 11 for composite beam design based on AISC 360, CSA S16 and Eurocode.
- Web penetrations for composite beam design based on AISC 360-16, AISC 36-10 and AISC 360-05 codes.
[Image: homepage.png]
[Image: comments.png]
No limits to creativity
[-] The following 25 users say Thank You to joker™ for this post:
  • ebzr, mohamz, PinkPant, RajaK, blaze, promo8, m_farajian, Nita1391, emmi, KhaLed-S.E, oanm2000, temp1366, tarugo, Dell_Brett, mowafi3m, bigone, giga, rcnet, SThirapat, TurboXUser, Andrew seah, jcbv, Rami11, golpesar, narendra
I supose this is the right link
[-] The following 32 users say Thank You to BennyP for this post:
  • amareen2000, mohamz, PinkPant, rami1976, joker™, zrilek, kirankumarklk, RajaK, blaze, m_farajian, caifan, Nita1391, ASEC, KhaLed-S.E, oyabun, mgdario, oanm2000, temp1366, tarugo, Dell_Brett, bao2004, ascetic19, mowafi3m, bigone, golpesar, milvio, gorky, giga, Batman07, TurboXUser, piseth, Rami11
While we wait the medicine for ETABS v17, I leave here the link to ETABS v17 Evaluation.
ALMF
[-] The following 12 users say Thank You to ALMF for this post:
  • caifan, Batman07, oanm2000, rcnet, kirankumarklk, SThirapat, Dell_Brett, giga, TurboXUser, piseth, spiderthan, bigone
ETABS v17.0.1 (X64 bit only)
ETABS 17.0.1 Enhancements:
[-] The following 16 users say Thank You to joker™ for this post:
  • Batman07, rami1976, zrilek, PinkPant, RajaK, oanm2000, emmi, tarugo, SThirapat, Dell_Brett, pedzaquino, ascetic19, piseth, chenamoy, TurboXUser, bigone
CSI ETABS v17.0.0
"Run after what you want while you can. Today's the youngest day of your life."
[-] The following 20 users say Thank You to KhaLed-S.E for this post:
  • RajaK, rami1976, chandra1234567, caifan, Nita1391, rezart, malc, techno, malee, subin91, mowafi3m, pedzaquino, Tuyen87, oanm2000, piseth, Rami11, cace-01, pram, golpesar, mgdario
concrete solution advocate
[-] The following 7 users say Thank You to concreteok for this post:
  • mowafi3m, oanm2000, Batman07, piseth, mohamz, cace-01, rami1976
Mirror Link
[-] The following 11 users say Thank You to malee for this post:
  • Andrew seah, mowafi3m, PinkPant, oanm2000, promo8, emmi, Batman07, piseth, rami1976, mgdario, narendra
new 17.0.1 crack released by the same cracker. (not tested)
[-] The following 4 users say Thank You to tomtumx for this post:
  • malc, RajaK, Batman07, chenamoy
Need mirror for post 8 (crk for v17.0.1)
Regards and thanx
Crack Version 17.0.1
[-] The following 28 users say Thank You to KhaLed-S.E for this post:
  • highcivil, Andrew seah, jcbv, Batman07, malee, Nita1391, emmi, Dell_Brett, zrilek, aslam, rezart, oanm2000, pedzaquino, milvio, Williams, mgdario, chenamoy, techno, caifan, cace-01, TurboXUser, l_namali, Rami11, golpesar, promo8, sodapas, bigone, narendra
