"Excel design Sheets" and "Typical Connection Drawings"
All CivilEA Users;
You can buy exclusive CivilEA products ("All Type Beam to Column Connections - Excel design Sheets" and "Typical Connection Drawings [Native Files]") for 70 USD.
Typical Beam to Columns Connection Drawings For IPE, HEA, HEB, UNP profiles, including Fixed connection for SMF, IMF frames (4 BOLTED EXTENDED UNSTIFFENED END PLATE, SMALL HAUNCHED BEAM, EXTENDED STIFFENED END PLATE, ...) and HINGED Connections (WITH END PLATE, WITH FIN PLATE, WITH BRACKET, ...)
Spread sheets cover all type connections that an engineer need to design:
  • All Types Beam to Column Flange Fixed Connection - BCFF1, BCFF2, BCFF3, BCFF4
  • Beam to Column Web Fixed Connection - BCWF
  • Beam to Column Flange Sliding Connection - BCFSL
  • All Types Beam to Column Web Sliding Connection - BCWSL, BCWSS
  • Beam to Column Slide Flange Hinged Connection - BCSF
  • Beam to Column Slide Web Hinged connection - BCSW
  • All Types Beam to Column Flange Hinged Connection - BCFH1, BCFH2
  • All Types Beam to Column Web Hinged Connection - BCWH1, BCWH2
All spread sheets are completely check and covers all requirement of AISC design code with refer to related clause.
you can see more information about these 2 package here:
PHP Code:
http://forum.civilea.com/thread-54726.html
Guests Can Not Buy Paid Contents. Please Login or Register to Buy Paid Contents.
[-] The following 18 users say Thank You to Administrator for this post:
  • seriousboy, asumi, ska51, mohamz, cargadory2k, KINIMOLEBA, falconado, jonygut, GMianG, ha72, jaks, sructme, planeti_x, persil20, henrybill, valinhas, mahfuzbangla, nhim4mat2006
I would purchase these if there was an US Imperial version available.
If you have these files converted to imperial please let me know.
If the price is different for converting these I understand.
Dgw7245
(04-10-2018, 09:59 PM)dgw7245 Wrote: I would purchase these if there was an US Imperial version available.
Dgw7245
hello
unfortunately they are in SI units and converted it to US imperial need totally revise it.
anyway our team are working on new version of US imperial units.
[-] The following 2 users say Thank You to Administrator for this post:
  • ska51, oanm2000
All Type Beam to Column Connections - Excell Sheets design Administrator 6 8,580 12-22-2018, 05:52 AM
Last Post: Administrator
Typical Connection Drawings [Native Files] Administrator 0 3,566 12-11-2017, 12:54 PM
