Large Deflection Inelastic Analysis of Space Trusses Using Generalized Displacement
Large Deflection Inelastic Analysis of Space Trusses Using Generalized Displacement Control Method
[Image: bsk5huuxhofj10y8q8k.jpeg]
This paper presents the large deflection inelastic analysis of space truss structures including both geometric and material nonlinearities. The geometric nonlinearity is considered based on an updated Lagrangian formulation, while the material nonlinearity is accounted for by tracing a complete stress-strain relationship in the elastoplastic range. The nonlinear equilibrium equations are solved using an incremental-iterative scheme based on the generalized displacement control method. This algorithm can accurately trace the equilibrium path of nonlinear problems with multiple limit points and snap-back points. A computer program is developed to predict the inelastic post-buckling behavior of space trusses. Numerical results obtained from the developed program are compared with those reported in the literature to demonstrate the accuracy of the proposed procedure.
Download Links:
Password:
NOTICE:
The downloaded file must be renamed to:
Large-Deflection-Inelastic-Analysis-of-Space-Trusses-Using-Generalized-Displacement-Control-Method.pdf
(add(complete) the .pdf suffix)
(post edited)
www.civilea.com
[-] The following 10 users say Thank You to rendel_© for this post:
  • vvvv, vvvv, kowheng, kowheng, cmorpar, cmorpar, subin91, subin91, zrilek, u4406014
Multivariate geostatistical approach to space-time data analysis arshiakh 0 1,053 04-08-2013, 06:34 PM
Last Post: arshiakh
Global buckling analysis of plane and space thin-walled frames in the context of GBT yanburak 2 1,961 04-05-2012, 04:51 PM
Last Post: ssobhan
Advanced inelastic static (pushover) analysis for earthquake applications cve_jule 0 1,512 09-02-2011, 01:16 PM
Last Post: cve_jule
ASCE 100(7), 1974 - OTANI - Inelastic analysis of RC frame structures Fem.Ing 0 1,590 08-19-2011, 05:30 PM
Last Post: Fem.Ing
An Incremental Response Spectrum Analysis Procedure Based on Inelastic Spectral Di... preceptor 0 1,684 10-31-2009, 10:52 AM
Last Post: preceptor
