Autodesk Point Layout 2018
[Image: 33375432814793402645.jpg]
[Image: 26809284342158773644.jpg]
Autodesk Point Layout automatically generates points from models within Autodesk® Revit®, Autodesk® AutoCAD®, and Autodesk® Navisworks® software. As you add points to the design, you embed X, Y, and Z coordinate information into your model. Each X, Y, and Z coordinate includes a unique point number and description. You can use the data you added to the model to inform the coordination process throughout the project lifecycle. Then you can export point coordinates to your compatible total station in the field so you lay out more accurate points, more quickly, reducing the risk of costly errors and delays.
[-] The following 6 users say Thank You to rami1976 for this post:
  • zrilek, RajaK, amindoxiti, thanzawtun, oanm2000, Dell_Brett
AutoDesk InfraWorks 360 Pro 2018 BennyP 1 1,854 03-10-2018, 12:15 PM
Autodesk Inventor 2018 BennyP 5 2,906 01-26-2018, 02:13 PM
Autodesk AutoCAD Plant 3D 2018 BennyP 1 2,067 12-18-2017, 10:32 PM
Autodesk Vehicle Tracking 2018 BennyP 2 2,446 12-18-2017, 10:27 PM
Autodesk 3ds Max 2018 rami1976 4 2,531 10-31-2017, 10:24 PM
