[Request] Lifting Lug Design - extract excel file(s) from this exe file
Does anyone know how to
extract the excel spreadsheet file/files out of this exe file
[Image: 05830170327453672598.jpg]
[Image: 54870314183146901806.jpg]
[Image: 96880016019247716317.jpg]
[Image: 69174954067971070260.jpg]
Read and accept the Terms and Conditions before using this spreadsheet.
Limitation of this trial version
This trial version is only for evaluation purpose.
You have a fixed number of 10 runs from its first launch on this computer.
After that it stops to work on this PC and a new activation key is needed or the full version should be purchased.
It is fully working with the following limitations:
• A pin diameter of 20 mm (~ 0,79 in) is fixed and it cannot be modified
• It is not possible to open/save external spreadsheets when it runs
• Excel toolbar is not visible
• Access to the Visual Basic Editor is not possible.
• Print function is disable
• Copy and paste functions are disable
• Save function is disable
What you find in the full version
• No expiration date
• No limit for pin diameter
• It is possible to open/save external spreadsheets when it runs
• Excel toolbar is visible
• Print function is available
• Save function is available
• Copy and paste functions are available
you need excel x64 installed in your computer in order to run this exe file
[-] The following 6 users say Thank You to usman for this post:
  • blaze, Dell_Brett, caifan, malc, oanm2000, febo927
[REQUEST] Sap2000 file of a Pushover analysis for concrete structures piromoplus 1 1,858 07-09-2015, 04:48 AM
Last Post: jupe01
