Autodesk Revit Live 2018 English - 64-bit
[Image: 17417465363450840959.jpg]
New features:
-LIVE Service
Level of Details geometry generation and material instancing have been added to the LIVE Service to enhance performance when working with large models and/or virtual reality.
Virtual Reality
-The handle used to move and rotate the Minimap has been replaced by using the Controller Grip buttons. This     provides a more natural and instinctive way to move, rotate, and scale your Minimap model.
-People Styles and Animation
You can choose between three visual styles for the RPC characters imported from Revit as part of your scene.
Characters have subtle animation that can be turned on or off.
Characters can be hidden or made visible.
-Header
The view name is part of the default header.
The scene’s header is editable.
-Textures
Texture orientation and offsets are consistent with what is set in Revit.
Customer texture files placed in C:\Program Files (x86)\Common Files\Autodesk Shared\Materials\Textures folder are used in LIVE service to generate the LIVE models.
-Publishing
 Presentations published from scenes prepared from the same Revit file but different 3D views no longer overwrite each other.
-Revit LT support
  • blaze, cace-01, oanm2000, aungaung, Dell_Brett
Autodesk Civil 3D 2019 English rami1976 4 1,809 09-07-2018, 09:28 PM
AUTODESK REVIT STRUCTURE V2014 WIN32/WIN64-ISO BennyP 4 4,034 04-21-2018, 10:51 PM
Last Post: joker™
AutoDesk InfraWorks 360 Pro 2018 BennyP 1 1,852 03-10-2018, 12:15 PM
Autodesk Inventor 2018 BennyP 5 2,905 01-26-2018, 02:13 PM
Autodesk AutoCAD Plant 3D 2018 BennyP 1 2,065 12-18-2017, 10:32 PM
