Autodesk AutoCAD LT 2018 (x86/x64)
Size: 1.47 GB / 1.60 GB
[Image: 46936587685515345118.jpg]
[Image: 33734134328523653864.jpg]
Quick Summary of AutoCAD 2018:
- Xrefs now default to relative path attachment and there are a few associated tweaks including find/replace path
- You can select objects off-screen (handier than it sounds)
- You can select objects with linetypes even when selecting the gaps
- File dialogs remember settings
- A couple more dialogs can be resized
- There are a couple more tiny user interface tweaks
- The stuff from 2017.1 is included, of course
- iDrop support is gone
  • camto2, rami1976, oanm2000, Wijono, Dell_Brett, Songoku, slowet
Autocad LT 2018 Direct links from Autodesk
_______________________________________________________________________
x64 bit link corrected
  • oanm2000, Wijono, Dell_Brett, slowet, narendra
Autodesk LT 2018 offline help
  • Dell_Brett, oanm2000, Songoku, slowet, narendra
Autodesk AutoCAD LT 2018.0.1 (X32-X64) Update
Readme
[-] The following 2 users say Thank You to rami1976 for this post:
Autodesk AutoCAD LT 2018.0.2(X32-X64) Update
Readme
[-] The following 3 users say Thank You to rami1976 for this post:
  • amindoxiti, Dell_Brett, oanm2000
AutoCAD Civil 3D 2018 BennyP 5 3,182 04-16-2018, 04:55 AM
AutoDesk InfraWorks 360 Pro 2018 BennyP 1 1,817 03-10-2018, 12:15 PM
Autodesk Inventor 2018 BennyP 5 2,860 01-26-2018, 02:13 PM
Autodesk AutoCAD Plant 3D 2018 BennyP 1 2,015 12-18-2017, 10:32 PM
Autodesk Vehicle Tracking 2018 BennyP 2 2,380 12-18-2017, 10:27 PM
