CSI SAFE 2016 v16.0.0.1114
Current time: 12-16-2018, 01:52 PM
Author: BennyP
Last Post: zrilek
Replies 6
Views 6246
[Image: 19312371167152992722.jpg]
New Features
The following list identifies some of the enhancements made to the program:
Automated application of post-tensioning to balance self weight.
Arbitrary tendon layout in plan and vertical profile.
Dynamic analysis capabilities for modal extraction.
Quick and easy generation of final printed reports:
Predefined or user-customized reports.
Graphical displays (see individual Display menu items).
Formatted tables of model definition, analysis and design results.
Detailed design sheets.
Automated pattern loading.
Finite Element Based reinforcing design.
Tracing of architectural drawings in Standard or DirectX graphics mode.
Hyperstatic analysis for secondary prestress forces.
Walls may be sloped to model ramps.
Columns may be sloped to model braces.
Support for numerous domestic and international design codes, including ACI 318-08 and Eurocode 2-2004.
Model Explorer window consisting of nodes and items that can be used to speed access to model features and output.
Equivalent frame method whereby a three-dimensional slab system is represented as a simplified series of two-dimensional planar frames.
CSI SAFE 16.0.1
[Image: comments.png]
No limits to creativity
[-] The following 27 users say Thank You to joker™ for this post:
  • zrilek, maad59, Andrew seah, cace-01, temp1366, simanta, blaze, Dell_Brett, Nita1391, promo8, oanm2000, malc, emmi, techno, mgdario, Rami11, pana2, oyabun, albani, faros3000, golpesar, deltalead, pedzaquino, mowafi3m, jaks, civilgen, erimajus
Dear.
This file on links
is invalid.
Please,update again.
[-] The following 3 users say Thank You to SThirapat for this post:
  • chenamoy, erthqkengnr™, pedzaquino
The file on links ..... is invalid.
Let see:
I downloaded, expanded and created the license.
[Image: 64279356776512380688.jpg]
[Image: 39291090779792635761.jpg]
[Image: 77903301999503721572.jpg]
[Image: 00092347197285725040.jpg]
[Image: 52331511238634473421.jpg]
[Image: 00797208856387733397.jpg]
And for your service a definition for invalid.
[Image: 61599231563095449505.jpg]
[-] The following 12 users say Thank You to BennyP for this post:
  • oyabun, oanm2000, SThirapat, 3fan, albani, joker™, jaks, golpesar, chenamoy, pedzaquino, mowafi3m, betinnn
A new KG (thanks to Lavteam) up to Nov 2018 for SAFE 2016
[-] The following 28 users say Thank You to joker™ for this post:
  • oanm2000, zrilek, zipatton, uncblue, Nita1391, Andrew seah, RajaK, hatkam, faros3000, cace-01, PinkPant, Dell_Brett, techno, miquan, jaks, tarugo, caifan, deltalead, highcivil, pana2, Batman07, narendra, smode, axcel, betinnn, mgdario, blackjack, nyungaw
new version friends, v16.0.2
Stability is the best policy.
[-] The following 23 users say Thank You to Arigato for this post:
  • rezart, joker™, zrilek, maad59, rami1976, uncblue, caifan, RajaK, simanta, PinkPant, Williams, oanm2000, faros3000, Dell_Brett, rendel_©, pana2, Batman07, emmi, smode, axcel, betinnn, jaks, mgdario
kg from post #5 works.
[-] The following 3 users say Thank You to zrilek for this post:
  • oanm2000, betinnn, jaks
