Pluralsight - 2D CNC Milling at Its Best in Autodesk Inventor HSM (
  • Year: 2016
  • Language: English
  • Format: mp4
  • Duration: 4:42
  • Size: 1.21 GB
  • Quality: DVDRip
Autodesk HSM CAM products have revolutionized the CNC Programming industry. This course will teach the fundamentals of Inventor's user interface and design tools to get you up and running quickly.
Parametric CAD design has been around for decades, and to some extent, so has its CAM side. For the majority of the industry, however, it was too difficult and too expensive to implement. Autodesk's Inventor HSM has changed that. In this course, 2D CNC Milling at Its Best in Autodesk Inventor HSM, you will learn all of the necessary basics behind Inventor's CAD tools so you can get up and running with its parametric CAD side to fully utilize the CAM side Inventor HSM provides. This course is presented in an assembly environment to get the best out of the Inventor side of INVHSM, such as quick and painless model replacement for revision changes that are a constant in manufacturing today. Along the way you will learn how Inventor's 2D CAM tools can advance your everyday CNC programming tasks with key tips, including how to create easy default settings, intuitive tool path structure, tool libraries, fast calculation speeds, and above all the parametric tool path control that Inventor offers. After finishing this course, you will be able to properly import parts from all CAD formats, 2D program in an individual part environment with Facing, 2D Adaptive Clearing, Contour, Pocket, Circular, Hole, and Thread Milling tool paths.
1.Course Overview 2m 9s
2.Getting Inventor Set, Application, and GUI Settings to Help You Succeed 54m 47s
3.Model Prep Using the Key Design Tools 34m 22s
4.Diving into 2D Milling Head-first: Part 11h 7m
5.Diving into 2D Milling Head-first: Part 241m 33s
6.The Assembly Difference, Best Practice, and Performance 49m 51s
7.The Revision Change / Inventor's Secret Weapon 32m 48s
[-] The following 2 users say Thank You to TAFATNEB for this post:
  • Dell_Brett, oanm2000
AutoDesk Inventor Video Tutorials mahfuzbangla 0 2,150 03-15-2010, 10:56 AM
Last Post: mahfuzbangla
