CSiBridge 2016 v18.2.0
[Image: homepage.png]
[-] The following 15 users say Thank You to Jackass for this post:
  • blaze, aema, slowet, oanm2000, mecheil.edwar, malc, Wijono, Andrew seah, mgdario, promo8, tarugo, PinkPant, faros3000, Rami11, rendel_©
The KeyGen for V18.1.0 is still valid and working for the new version 18.2.0
[-] The following 9 users say Thank You to mecheil.edwar for this post:
  • malc, Dell_Brett, oanm2000, promo8, tarugo, PinkPant, simanta, TurboXUser, Rami11
Torrent mirror (32 - 64 bit with keygen)
[-] The following 6 users say Thank You to TurboXUser for this post:
  • sabooryan, Dell_Brett, blaze, apocalipse, TAFATNEB, odiclas
CSI Bridge 2016 version 18.2.0
[Image: 47181643243024023994.jpg]
Computers and Structures, Inc. (CSI), a structural and earthquake engineering software company, has released 18.2.0 version of Bridge 2016, is specialized analysis and design software tailored for the engineering of bridge systems.
CSiBridge is specialized analysis and design software tailored for the engineering of bridge systems. Suspension, cable-stay, elevated-roadway, and other types of bridge systems may be modeled and designed to suit any one of a variety of purposes, including means for crossing water, linking points between shear terrain, or extending over highway infrastructure. Customized controls and features integrate across a powerful object-based modeling environment to offer an intuitive, practical, and productive computational tool for bridge engineering. Advanced modeling features and sophisticated analysis techniques account for dynamic effects, inelastic behavior, and geometric nonlinearity. Code-based templates streamline the engineering process from model definition through analysis, design optimization, and the generation of comprehensive output reports. CSiBridge is the premier software for bridge engineering.
CSiBridge 2016 version 18.2.0 Enhancements:
- Graphical User Interface
New display allows displaying all loads, within a single load pattern, on all object types, in a single display.
- Modeling
Modeling settings can be saved and later used when starting a new model.
- Bridge Modeler
Define bents without cap-beams for use with concrete box-girder bridges.
Orient internal diaphragms at bent support locations in steel U-girder bridge sections.
- Loading
Response spectrum function added for Russian codes.
Response spectrum function added to Chinese code CJJ 166-2011 and updated for Chinese code JTG B02-2013.
Russian response spectrum SP 14.13330.2014.
Chinese vehicle library updated.
Chinese bridge load combinations updated with Fundamental, Frequent and Quasi-permanent combinations.
- Analysis
Event-to-event solution strategy implemented as an option for nonlinear direct-integration time-history load cases.
Increase in the speed of nonlinear static and direct-integration time-history analyses.
Increase in speed of moving load analyses for calculating vehicle response for frame objects and join reactions.
- Bridge Design
Bridge live-load modeling and superstructure design and rating enhancement to AASHTO code.
Chinese bridge seismic design enhancement.
- Results Display & Output
Correspondence can now be explicitly requested for the Analysis Results.
[Image: comments.png]
[-] The following 4 users say Thank You to TAFATNEB for this post:
  • PinkPant, Dell_Brett, eng donny, oanm2000
