AutoCAD Structure Detailing 2010 Multilingual SP2 Full
Don't support for windows7
[Image: 24tjzs2wy1xojovk5sf.png]
AutoCAD® Structural Detailing software, built on the familiar AutoCAD® platform, enhances productivity with precise detailing and creation of fabrication shop drawings for steel and concrete structures. AutoCAD Structural Detailing includes two powerful toolsets for structural steel and concrete reinforcement detailing projects. AutoCAD Structural Detailing is part of AutoCAD® Revit® Structure Suite.
AutoCAD® Structural Detailing software enables you to quickly and efficiently generate detailing and creation of fabrication shop drawings for reinforced concrete and steel structures. AutoCAD® Structural Detailing: Intelligent Structural Objects
In AutoCAD Structural Detailing, engineers and drafters can create structural steel models or rebar drawings using intelligent objects such as beams, plates, columns, walls, and reinforcement bars, rather than lines and curves. You can virtually cut, lengthen, bend, split, and merge objects. They dynamically react to changes and automatically update material takeoffs.
AutoCAD® Structural Detailing: Powerful Macros
Powerful Macros
AutoCAD Structural Detailing provides special tools and smart macros that enable fast automation of time-consuming structural tasks. Use macros to generate typical parts of steel structures (including connections, roof trusses, stairs, railings, and ladders), automatically place elements (such as grates or purlins), or generate complete concrete reinforcement drawings of typical parts of structures, together with rebar descriptions and material takeoffs.
screenshots:
[Image: 38kxufp1hh363n906b9y.png]
Download Links:
or
Product Key:
keygen X-force
Hot fix 4:
Password:
1.Follows the rules
2.Use "Search" before posting
4.Do not spam
5.Respect the other members
(10-28-2009, 07:18 AM)rohailiyaz Wrote: i am using mediafire to dload bt i cant dload 11 par..dnt knw whts the reason. could sum1 kindly upload it seperatly?
dear rohailiyaz
Use IE 8.0 instead of Fire Fox to download part11 or download with new links:
regard
1.Follows the rules
4.Do not spam
[-] The following 3 users say Thank You to timosi™ for this post:
  • rohailiyaz, rohailiyaz, Nilupa
About SP1:
About SP2:
About Hot Fix1:
About Hot Fix2:
About Hot Fix3:
It will expain all
regard
timosi
1.Follows the rules
4.Do not spam
[-] The following 11 users say Thank You to timosi™ for this post:
  • niki102, niki102, Ultra Zone, Ultra Zone, yucapareja, yucapareja, Dell_Brett, Dell_Brett, mkbiksi, sssmou, ruwan75
Dear Imran,
Thank you for your reply.I have successfully un zip the files but with lot of errors.My installation was stopped after 25% of installation.
I have just successfully installed AutoCad Revit Structure Suite 2010 from the others links given below.I am using 32 Bits Window Vista. You have to use KeyGen posted by Mr.Timosi to crack the same.You can download one link at a time in half an hour interval but downloading speed is good.
Thanks.
Fiaz
[-] The following 1 user says Thank You to fiaz for this post:
  • u4406014
Autodesk AutoCAD Structural Detailing 2014 (x86/x64) AIO BennyP 4 5,709 04-11-2015, 11:30 AM
Last Post: alnasir
Autodesk AutoCAD Structural Detailing 2015 64bit BennyP 1 7,693 03-16-2015, 09:45 AM
Last Post: gianniorlati
Portable Autocad 2010 Lite kirankumarklk 2 2,360 04-02-2013, 08:05 AM
Autodesk AutoCAD Structural Detailing 2013 (x86/x64) BennyP 10 12,450 11-27-2012, 10:41 AM
Last Post: devilmaycry
AutoCAD Structural Detailing 2013 (x32/x64) Trial BennyP 0 2,424 04-01-2012, 04:16 PM
