Bentley Limcon 03.63.02.04
Current time: 07-18-2018, 03:08 PM
Author: rami1976
Last Post: joker™
Replies 6
Views 2330
Bentley Limcon 03.63.02.04 build 12/10/2015
[Image: 72749864359516519046.jpg]
What's New :
New Connections
   Hollow structural section connections.
   4-bolt and 8-bolt moment end plate connections for RHS/SHS.
   AISC flush and extended multiple row moment end plate connections.
   Bolt goup and weld group.
Other New Features
   Options for checking to AISC LRFD and BS 5950*.
   Additional libraries, bolt sizes, and grades.
   Section library management / section input.
   Display of section and member mark in virtual reality view.
   Optional elastic/plastic analysis for splices and moment connections.
Additions to Existing Connections
   Axial loads in WSP, FEP, and ACLT connections.
   Column shear in haunched moment end plate connection.
   Option for 4 lines of bolts in splice plates and moment end plates.
   More than 2 columns of bolts in web splice plates.
   More than 2 columns of bolts in bracing cleat.
   Checking of attached plate and member in bracing cleat connection.
   Revised weld capacity requirement in web side plate connection.
[Image: comments.png]
  • Related Link:
[-] The following 22 users say Thank You to rami1976 for this post:
  • oanm2000, joker™, ISTRAKTURA, faros3000, Dell_Brett, psk62, shaker, malc, adams, chenamoy, karthikeyans3d, Williams, harsono, ting tsai huang, monter, rendel_©, deltalead, jcbv, mowafi3m, jacky899, sodapas, Aviator
Hello Guys,
The Link is not the original posted !
Malware
Malware detected by Kaspersky and no password is required to unzip the file ....
Can someone reload, Please ?
Thanks for the help in advance.
The file was downloaded 128 times without problem , but due to your request this is a mirror :
[-] The following 8 users say Thank You to rami1976 for this post:
  • Dell_Brett, zrilek, Pitagora, simanta, joker™, bridgeengineer, mgdario, Arigato
Thanks for Your upload.
I apologize for my insistence,
but the original Post refers for "Limcon 03.63.02.04" not "Limcon 03.63.01.11" as You posted Today.
Can You reload this release ?
Thanks in advance
[-] The following 1 user says Thank You to Pitagora for this post:
  • angelarias
Mirror of post 1:
[-] The following 9 users say Thank You to rami1976 for this post:
  • slowet, Dell_Brett, Albert, blaze, melekeen, Andrew seah, ykhackhack, MOSS2000, jacky899
[Image: 86833554761322874408.jpg]
Quickly design and review your steel connections, such as beam to column, brace end, member splices, anchorage to concrete, complicated multi-member joints, and many more. Thanks to our library of international standard connection types, you save time and money by quickly designing connections and producing your CAD drawings all within one easy-to-use application. You can easily verify your connection results and quickly generate a concise design report summarizing all checks and connection statuses. -
[-] The following 9 users say Thank You to eng donny for this post:
  • f_slikken, PinkPant, simanta, jaks, jacky899, harsono, Dell_Brett, hmwere, oanm2000
Bentley Limcon 03.63.02.06 (Date: 2/16/2016)
[Image: 55886139150627189415.png]
No limits to creativity
[-] The following 24 users say Thank You to joker™ for this post:
  • zrilek, slowet, pedzaquino, malc, Dell_Brett, hmwere, subin91, jcbv, Andrew seah, oanm2000, cristi, PinkPant, promo8, mowafi3m, monter, l_namali, jaks, febo927, caifan, harsono, rendel_©, Batman07, melekeen, rfireman
Bentley Limcon v3.63.01.11 build 13.06.2014 bigone 2 7,276 04-24-2015, 03:04 PM
Last Post: bigone
