Autocad civil3d 2017
Current time: 02-22-2018, 01:54 PM
Author: rami1976
Last Post: temp1366
Replies 1
Views 1991
[/align]
[Image: 62995724417872050396.jpg]
Civil 3D AutoCAD - program based on the platform of AutoCAD and designed for surveyors, designers of the general plan, the designers of linear structures. A key feature of the program is the intelligent link between the objects, which dynamically update all linked objects in amending the results of research or design solutions.
Main advantages
- The rapid formation of the concept and implementation of the project;
- Flexible design, based on the interaction of objects, allowing to achieve the accuracy and coherence of all parts of the project;
- Multi-user access to the project and its elements;
- The possibility of rapid development, project evaluation and preparation of output documents;
- Combination of drawing possibilities AutoCAD and specialized design features;
- A rich set of API functions (Application Programming Interface) that allows you to build solutions based on a common data model;
- The ability to increase functionality;
- Dynamic engineering model that contains the basic elements of geometry and maintains intelligent relationships between objects (point, surface, land, roads, and planning);
- Support of drawing standards and styles;
- Automatic generation of plans;
- Functionality of AutoCAD the Map 3D .
and much more..
[-] The following 14 users say Thank You to rami1976 for this post:
  • temp1366, oanm2000, bridgeengineer, Dell_Brett, cace-01, mgdario, blaze, snakes, hmwere, julioreptil, TurboXUser, rezaismaniar, tumangik, DropoutJeep
Autodesk Civil 3d 2017 Offline Help (English):
Sample PKT Files for the Autodesk Subassembly Composer for Autodesk AutoCAD Civil 3D 2017:
[-] The following 5 users say Thank You to temp1366 for this post:
  • Dell_Brett, oanm2000, PinkPant, snakes, KINIMOLEBA
Autodesk AutoCAD Civil3D v2012 Win32/Win64 BennyP 12 10,109 01-04-2017, 02:08 PM
Last Post: oanm2000
Autodesk AutoCAD 2017.1.1 TAFATNEB 1 1,610 12-18-2016, 05:58 AM
Autocad Civil 3D Geotechnical Module 2017 Gabemzaman 0 1,280 11-03-2016, 11:14 AM
Last Post: Gabemzaman
Autocad Civil 3D Bridge Modelling Module 2017 Gabemzaman 0 1,084 11-03-2016, 11:02 AM
AutoCAD Mechanical 2017 temp1366 4 2,263 10-03-2016, 10:03 AM
