Autodesk REVIT 2017 (x64)
Current time: 07-22-2018, 04:17 AM
Author: BennyP
Last Post: tudao
Replies 8
Views 5825
[Image: 21093749122594722902.gif]
[Image: 40220607077281138002.gif]
[Image: 77646154600580883414.gif]
[Image: 58239447757067790105.gif]
Revit is a design and documentation platform that supports the design, drawings, and schedules required for building information modeling (BIM). BIM delivers information about project design, scope, quantities, and phases when you need it.
[-] The following 27 users say Thank You to BennyP for this post:
  • cace-01, iamnowtheone, RajaK, Dell_Brett, stosto6666, temp1366, oanm2000, PinkPant, bridgeengineer, kkding, zrilek, faros3000, gafi, Rodmo376, rami1976, blaze, TurboXUser, yutt, promo8, malc, bluefish80, raymelito, mowafi3m, tudao, Batman07, deltalead, kristoffer_89
here are links for Revit LT version
Sorry I can not post print screens because my system is 32bit win7
Civil worker/labor schould know :"How?"
Civil engineer schould know:"Why?"
[-] The following 3 users say Thank You to bridgeengineer for this post:
  • zrilek, pousin, mowafi3m
Structural Analysis Toolkit 2017
The Structural Analysis Toolkit for Autodesk® Revit® software is a suite of tools that supports the Building Information Modeling (BIM) process and allows structural engineers to analyze structures from within the Revit environment.
Using this toolkit structural designers and engineers can optimize their workflows in the cloud and on the desktop by using the analytical model built in Revit to conduct cloud-based structural analysis with access to Autodesk 360 services and by extending the Revit model to Autodesk Robot Structural Analysis Professional software or supported third party analysis solutions. Once complete, analysis results can be easily stored and explored in the Revit environment.
The toolkit contains the following items:
  • Link with Autodesk® Robot™ Structural Analysis Professional
Use it to perform advanced analyses after transferring a Revit analytical model to Autodesk® Robot™ Structural Analysis Professional (Robot). It is a structural analysis and design software application. Use it to perform linear and nonlinear analyses of any structure type and shape and to design steel, concrete, and timber elements of a structure. Autodesk® 360 Structural Analysis for Revit
  • Autodesk® 360 Structural Analysis for Revit
Use it to perform a cloud-based structural analysis of a Revit analytical model. You can perform a static analysis and a gravity analysis. Explore results in the Revit project or on the Autodesk® 360 S Analysis Professional structural Analysis website.
  • Structural Results Storage and Exploration tools
Use Results Manager to review, download, or remove results packages. Use Results Explorer to display result maps and diagrams on elements of an analytical model in Revit.
[-] The following 9 users say Thank You to temp1366 for this post:
  • PinkPant, blaze, oanm2000, stosto6666, zrilek, Dell_Brett, cace-01, TurboXUser, mowafi3m
Advance Steel 2017 Extension
With Advance Steel 2017 Extension, Autodesk® Revit® 2017 users can quickly connect their models to Advance Steel 2017 using the export, import and synchronize functionalities to transfer the model BIM data in LOD350 for Structural Steel. This interoperability helps users to more rapidly produce general arrangement drawings, fabrication drawings, BOMs, and NC files for steel structures.
Using synchronization of BIM data between applications users can update the modifications without having to reimport the entire structure. Synchronization also reduces the risk of potential errors by offering the possibility to track changes made on the same model in different applications.
Using Advance Steel 2017 Extension, the BIM data from the Revit model can be imported or exported also in other formats such as SDNF (Version 2.0 and Version 3.0), CIS2 and PSS.
[Image: homepage.png]
[-] The following 6 users say Thank You to temp1366 for this post:
  • oanm2000, zrilek, Dell_Brett, cace-01, TurboXUser, mowafi3m
Export to ETABS
Nasser’s Tools are custom plug-ins created to enhance Autodesk Revit® Integration with the Structural Analysis Software ETABS. This plug-in also has some other functions which structural engineers would find useful.
Here are some of the Tool’s Features:
The following elements will be exported to ETABS (as a *.e2k file):
·         Columns
·         Braces
·         Beams
·         Walls
·         Slabs
·         Slab Openings
·         Grids
·         Levels
·         Rigid Links
Note:
* If the Script does not recognize the Section Family, it will export it as a null element which can later be edited in ETABS.
* You have the option of rotating (about the Global Z Axis) your analytical model in Revit when exporting to ETABS (without changing your Revit model's geometry).
* The tool is a one way tool and cannot be used to reimport your ETABS model back into Revit.
* You have the option of exporting All Elements, Selected Elements or Selected Work sets.
[-] The following 5 users say Thank You to temp1366 for this post:
  • oanm2000, zrilek, Dell_Brett, cace-01, mowafi3m
Reinforcement sketch
This addin allows you to create sketches for reinforcement. Thumbnails are generated as graphics files like png and placed in a separate folder with the project file.
When changes are made to the project you should run the command to update the schedule.
[-] The following 8 users say Thank You to temp1366 for this post:
  • oanm2000, PinkPant, zrilek, Dell_Brett, cace-01, monter, TurboXUser, mowafi3m
Please reload, dead links for post #4,#5 and #6
[-] The following 3 users say Thank You to davidc for this post:
  • gafi, apocalipse, vinnunsam
The 4 Previous EXT.&Tools
"Run after what you want while you can. Today's the youngest day of your life."
[-] The following 15 users say Thank You to KhaLed-S.E for this post:
  • temp1366, Dell_Brett, oanm2000, zrilek, cace-01, PinkPant, raymelito, bridgeengineer, malc, bao2004, mowafi3m, Williams, apocalipse, Batman07, melekeen
Where do I find the keygen
Moderator Note:
There's no keygen.
It's a "plug in" for REVIT. The software must be previously installed and patched.
[-] The following 1 user says Thank You to tudao for this post:
  • Rihpi
AUTODESK REVIT STRUCTURE V2014 WIN32/WIN64-ISO BennyP 4 3,730 04-21-2018, 10:51 PM
Last Post: joker™
Autodesk Revit 2016 (x64) BennyP 1 3,132 10-19-2017, 10:10 PM
Last Post: joker™
AUTODESK REVIT MEP V2014-ISO (x32/x64) BennyP 1 1,628 10-15-2017, 02:33 PM
Last Post: joker™
AUTODESK REVIT ARCHITECTURE V2014-ISO (x32/x64) BennyP 1 2,163 10-15-2017, 02:31 PM
Last Post: joker™
Autodesk REVIT 2018 LT BennyP 3 1,741 10-11-2017, 08:38 PM
