Autodesk Vehicle Tracking 2017
Current time: 06-22-2018, 12:31 AM
Author: Krite
Replies 3
Views 2330
[Image: 46196735493036724280.jpg]
Autodesk Inc., a world leader in 3D design software for entertainment, natural resources, manufacturing, engineering, construction, and civil infrastructure, announced the release of Vehicle Tracking 2017, is a comprehensive transportation analysis and design solution for vehicle swept path analysis.
The software enables engineers, designers, and planners at government agencies and engineering consulting firms working on transportation or site design projects to predictably evaluate vehicle movements. In addition, you can draft and review intersections using analysis and simulation tools that are integrated as part of the total design process.
Integrate planning and design processes with analysis and simulation that works within a familiar AutoCAD environment
- Predictably evaluate the movements of steered vehicles, light rail vehicles, and aircraft, and design parking lots and intersections using analysis and simulation tools that are integrated with Autodesk software—including Autodesk AutoCAD, Autodesk AutoCAD Civil 3D, Autodesk AutoCAD Architecture, Autodesk AutoCAD Plant 3D, Autodesk AutoCAD Map 3D, and Autodesk AutoCAD® Utility Design.
- Connect the modeling and design processes to enable the reuse of preliminary design work in the detail design phase.
- More easily consider safety factors—such as sight lines based on standard design speeds—interactively during the design process.
Speed planning and design processes
- Use real-time operational analysis to optimize project performance in less time.
- Expedite the preliminary design phase with easy-to-use, real-time simulation and drag-and-drop tools.
- Minimize rework by creating vehicle paths that can be saved and referred to later in the process to help maintain up-to-date animations.
More quickly evaluate 3D models of alternatives in order to optimize designs
- Quickly and easily explore alternative design solutions with the production of multiple layout options that adapt automatically to the dynamic 3D model in Civil 3D.
- Evaluate safety and standards compliance and help meet permitting requirements for parking layout, refuse and emergency vehicle access, and loading bay access.
- Easily analyze vertical clearance, vertical grades, and crossfalls for vehicle access using 3D proposed surface models.
[Image: homepage.png]
[-] The following 7 users say Thank You to Krite for this post:
  • oanm2000, temp1366, PinkPant, zrilek, Dell_Brett, iamnowtheone, monter
[Image: comments.png]
POST EDITED BY MODERATOR:
LINK CODE PROTECTED (INSIDE COMMENTS)
[-] The following 5 users say Thank You to TAFATNEB for this post:
  • zrilek, oanm2000, PinkPant, cace-01, karroumk
Direct download
Quality: Unspecified
I CANNOT CHANGE THE DIRECTION OF THE WIND, BUT I CAN ADJUST MY SAILS TO ALWAYS REACH MY DESTINATION - JIMMY DEAN
[-] The following 7 users say Thank You to Gabemzaman for this post:
  • zrilek, blaze, oanm2000, Dell_Brett, bridgeengineer, cace-01, karroumk
Autodesk Vehicle Tracking 2017 SP2 (2017.2)
Autodesk Vehicle Tracking 2017.2 Update Fixed Issues
   Major re-arrangement and structure of dialog boxes and user interface to fix multiple localization issues in all supported languages.
   Fixes an issue in the Advanced Vehicle Editor when trying to add wing mirrors to a body outline of a trailer.
   Fixes an issue where road markings were not available in the Roundabout Standard or Properties pages.
   Fixes an issue when changing from stockdale to island to island crown lines caused missing corridor regions on roundabouts.
   Fixes an issue when in the advanced vehicle shape outline editor, defaulted values were no longer remembered when changing shape type. This was most noticeable when changing a rectangle shape with zero Y Offset to a wing mirror and then back again, the Y offset would change from zero to the width of the vehicle.
   Fixes an issue in some languages where Combo and List boxes showed vertical bars "||||||" and not the text.
   Fixes an issue where Max and Min lanes on the new arm dialog box did not match those defined in the Roundabout standard for the blend point at the blend point on the road but contained the values for the yield line.
   Fixes an issue with the vehicle wizard and custom defined body outlines where length and wing span values appeared not to change when edited. etc..
see more at  :
[-] The following 7 users say Thank You to rami1976 for this post:
  • Dell_Brett, PinkPant, zrilek, oanm2000, cace-01, bridgeengineer, karroumk
Autodesk Vehicle Tracking 2018 BennyP 2 1,905 12-18-2017, 10:27 PM
Autodesk Structural Bridge Design 2017 TAFATNEB 3 2,523 03-31-2017, 11:00 AM
Autodesk Revit 2017 Add-Ins exclusive To Autodesk Subscription Customers bus001 0 1,299 03-03-2017, 12:05 PM
Last Post: bus001
AutoDesk InfraWorks 360 2017.3 TAFATNEB 2 1,051 03-01-2017, 02:35 PM
Autodesk Revit 2017.1.1 TAFATNEB 0 1,547 12-19-2016, 08:26 AM
