Autodesk Advance Steel 2017 (x64)
Current time: 08-16-2018, 08:01 AM
Author: BennyP
Replies 2
Views 4109
[Image: 04128099554636707719.gif]
[Image: 81641579199346860037.gif]
Complete toolset for structural steel design
Advance Steel detailing software for structural steel design provides engineering and detailing professionals with tools for structural engineering.
[-] The following 27 users say Thank You to BennyP for this post:
  • zrilek, temp1366, TAFATNEB, PinkPant, jcbv, stosto6666, oanm2000, telecivil, malc, jonny78, cordoba123, Rodmo376, dizz, Dell_Brett, aema, dovsky, monter, rodleyzed, caifan, dquan373, andiengineering, subin91, mgdario, oreslaw, gabe, raymelito, stldtls
Robot-AdvanceSteel Link 2017
With Robot-AdvanceSteel Link, you can export a Robot structural model using the smlx format. You can then import the smlx file in Advance Steel in order to detail steel connections and automatically generate fabrication documents. From Robot, you can export values of internal forces with the model to the smlx file. After importing the file to Advance Steel, you can use these values to perform code checking of connections.
Conversely, you can export a model from Advance Steel in order to perform structural analysis and code checking in Robot.
You can also track changes in the same model in both applications using the synchronization feature.
[Image: homepage.png]
[-] The following 8 users say Thank You to temp1366 for this post:
  • jcbv, PinkPant, oanm2000, zrilek, malc, Dell_Brett, cace-01, mgdario
Product Key
Autodesk Advance Steel 2017 959I1
[-] The following 10 users say Thank You to BennyP for this post:
  • cace-01, zrilek, Dell_Brett, malc, dquan373, concreteok, PinkPant, oreslaw, gabe, aema
Autodesk Advance Steel 2019 ML rami1976 1 878 04-13-2018, 02:51 PM
AutoDesk Advance Steel 2018 rami1976 1 2,296 04-07-2017, 05:55 AM
Autodesk Structural Bridge Design 2017 TAFATNEB 3 2,599 03-31-2017, 11:00 AM
Autodesk Revit 2017 Add-Ins exclusive To Autodesk Subscription Customers bus001 0 1,349 03-03-2017, 12:05 PM
Last Post: bus001
AutoDesk InfraWorks 360 2017.3 TAFATNEB 2 1,120 03-01-2017, 02:35 PM
