Autodesk Robot Structural Analysis Professional 2017 x64
Current time: 04-27-2018, 03:40 AM
Author: temp1366
Last Post: temp1366
Replies 2
Views 3767
[Image: 29118656544372056510.jpg]
Robot Structural Analysis is structural analysis software for structural modeling to simulate wind load in the design and engineering workflow.
[Image: homepage.png]
[-] The following 24 users say Thank You to temp1366 for this post:
  • thanzawtun, blaze, TAFATNEB, subin91, stosto6666, jcbv, PinkPant, zrilek, oanm2000, malc, lisine, nickycruz, cace-01, Rodmo376, chrono146, SCREAM7890, TurboXUser, raymelito, oreslaw, promo8, julioreptil, nyungaw, civilgen, vinnunsam
Autodesk Robot Structural Analysis Pro 2017 .sfx
  • Size:
  • 803.5 MB
  • Quality:
  • DVDRip
Autodesk Inc., a world leader in 3D design software for entertainment, natural resources, manufacturing, engineering, construction, and civil infrastructure, announced the release of Robot Structural Analysis Pro 2017. This software provides engineers with advanced BIM-integrated analysis and design tools to understand the behavior of any structure type and verify code compliance.
Autodesk Robot Structural Analysis Professional software provides structural engineers with advanced building analysis capabilities for large and complex structures. The structural analysis software offers a smoother workflow and interoperability with Autodesk Revit Structure software to extend the Building Information Modeling (BIM) process, enabling engineers to more quickly perform comprehensive analysis of a variety of structures.
Create structural models and perform structural analysis within Robot Structural Analysis Professional, and seamlessly transfer the model and results to AutoCAD Structural Detailing software to generate fabrication drawings. Within this ecosystem of structural engineering software, structural engineers can take advantage of an integrated workflow from design through analysis to fabrication.
[Image: comments.png]
Post Edited by Moderator:
Link code protected inside Comments
Post edited by moderator
Link code protected (inside comments)
[-] The following 5 users say Thank You to TAFATNEB for this post:
  • PinkPant, oanm2000, mgdario, sructme, raymelito
Composite Beam Design Extension 2017
This application lets you perform static analysis and design of composite steel beams in an Autodesk® Robot™ Structural Analysis Professional model. Using this application, you can quickly design and check the behavior of composite beams. You can also design an entire composite floor system on a floor by floor basis within a Robot model.
This application lets you select from two methods of calculating internal forces: Internal Engine and Robot Structural Analysis (for advanced users).
All design is based on ANSI/AISC 360-10.
This application works for composite steel beam design, but you can also use it for non-composite design.
The basic functionalities include interactive and automatic design of composite beams.
Full bidirectional integration with the Robot model is achieved using this application.
[-] The following 10 users say Thank You to temp1366 for this post:
  • blaze, PinkPant, oanm2000, zrilek, malc, Dell_Brett, subin91, SCREAM7890, raymelito, oreslaw
Autodesk Robot Structural Analysis Professional 2019 joker™ 0 478 04-12-2018, 01:57 PM
Last Post: joker™
Autodesk Robot Structural Analysis Professional 2018 rami1976 4 4,016 10-11-2017, 08:47 PM
Autodesk Structural Bridge Design 2017 TAFATNEB 3 2,428 03-31-2017, 11:00 AM
Autodesk Revit 2017 Add-Ins exclusive To Autodesk Subscription Customers bus001 0 1,227 03-03-2017, 12:05 PM
Last Post: bus001
AutoDesk InfraWorks 360 2017.3 TAFATNEB 2 970 03-01-2017, 02:35 PM
