Design of Steel-to-Concrete Joints Design Manual I
Current time: 02-22-2018, 01:49 PM
Author: rami1976
Last Post: concreteok
Replies 4
Views 1583
Design of Steel-to-Concrete Joints -Design Manual I
Author(s)/Editor(s): František Wald ,Jan Hofmann & Ulrike Kuhlmann | Size: 3.5 MB | Format: PDF | Quality: Original preprint | Year: 2014 | pages: 179
[Image: 96721066030496929074.jpg]
The mixed building technology allows to utilise the best performance of all structural materials available such as steel, concrete, timber and glass.Engineers of steel structures in practice are often faced with the question of economical design of steel to concrete joints, because some structural elements, such as foundations, stair cases and fire protection walls, are optimal of concrete. A gap in knowledge between the design of fastenings in concrete and steel design was abridged by standardized joint solutions developed in the INFASO project, which profit from the advantage of steel as a very flexible and applicable material and allow an intelligent connection between steel and concrete building elements.
The requirements for such joint solutions are easy fabrication, quick erection, applicability in existing structures, high loading capacity and sufficient deformation capacity. One joint solution is the use of anchor plates with welded headed studs or other fasteners such as post-installed anchors. Thereby a steel beam can be connected by butt straps, cams or a beam end plate connected by threaded bolts on the steel plate encased in concrete.
[-] The following 15 users say Thank You to rami1976 for this post:
  • amindoxiti, f_slikken, stosto6666, zrilek, milova, bridgeengineer, agelos100, oanm2000, ting tsai huang, ssobhan, igor1234, psk62, allagui10, stigtg, zego2000
forum standard mandatory password should be used.
[-] The following 7 users say Thank You to sabooryan for this post:
  • Kurucz, subin91, hmwere, cace-01, ykhackhack, oanm2000, chrono146
[-] The following 22 users say Thank You to civilnextgen for this post:
  • cace-01, zrilek, Dell_Brett, gulilero, oanm2000, concreteok, telecivil, Andrew seah, tomtumx, rendel_©, ebzr, blaze, slowet, avge, ssobhan, yanburak, cordoba123, sodapas, psk62, Kurucz, knrsa, simanta
Design of Steel-to-Concrete Joints -Design Manual II
  • Jackass, cace-01, rezart, jcbv, carolinandra, Dell_Brett, oanm2000, telecivil, ting tsai huang, malc, bridgeengineer, sodapas, draluka, stigtg, zrilek
for those who are not keen on hulkload and having problem with uploadboy
manual I (manual II posted in #3) direct link
concrete solution advocate
[-] The following 28 users say Thank You to concreteok for this post:
  • telecivil, Andrew seah, oanm2000, Dell_Brett, tomtumx, malc, rendel_©, ebzr, zrilek, Trishu999, ruaumoko, PinkPant, Jackass, araza023, mgdario, yanburak, cordoba123, sodapas, ykhackhack, chairatpk, Kurucz, draluka, promo8, zego2000, heogay43, simanta, monter, harsono
Tall building design: steel, concrete, and composite systems asim99 2 2,057 03-28-2017, 06:16 AM
Last Post: Wijono
Principles of Structural Design: Wood, Steel, and Concrete, Second Edition cace-01 1 1,686 06-15-2015, 04:56 PM
Last Post: sinamaleki
Structural Shear Joints: Analyses, Properties And Design for Repeat Loading Dell_Brett 3 2,373 12-26-2014, 11:21 PM
Last Post: Veggeta
Manual on design of steel structures in seismic zones jorgeramos 2 2,647 12-18-2010, 10:01 AM
