CSI Etabs 2015 15.20 x64
Current time: 07-20-2018, 05:27 PM
Author: BennyP
Last Post: Arigato
Replies 7
Views 8878
[Image: 26404803032240213748.jpg]
ETABS 15.2.0 Enhancements
[Image: CEF.jpg]
Hi
32bit edition only in Civilea
[-] The following 27 users say Thank You to Jackass for this post:
  • learner20, cace-01, ykhackhack, bridgeengineer, mowafi3m, oanm2000, temp1366, Dell_Brett, RajaK, PinkPant, SThirapat, Rami11, mgdario, araza023, simanta, rendel_©, harsono, faxel, knrsa, elestructural, visu, bigone, jaks, oyabun, ting tsai huang, TAFATNEB, odiclas
CSI ETABS 2015 version 15.2.0 | 1.0 Gb
[Image: 18511037576656678781.jpg]
Computers and Structures, Inc. (CSI), leader in software tools for structural and earthquake engineering, has released 15.2.0 version of ETABS 2015 is a civil engineering program that design and analyse steel and concrete structures using finite element method.
ETABS is an engineering software product that caters to multi-story building analysis and design. Modeling tools and templates, code-based load prescriptions, analysis methods and solution techniques, all coordinate with the grid-like geometry unique to this class of structure. Basic or advanced systems under static or dynamic conditions may be evaluated using ETABS. For a sophisticated assessment of seismic performance, modal and direct-integration time-history analyses may couple with P-Delta and Large Displacement effects. Nonlinear links and concentrated PMM or fiber hinges may capture material nonlinearity under monotonic or hysteretic behavior. Intuitive and integrated features make applications of any complexity practical to implement. Interoperability with a series of design and documentation platforms makes ETABS a coordinated and productive tool for designs which range from simple 2D frames to elaborate modern high-rises.
ETABS 15.2.0 Enhancements:
International Design Codes
- Shear-Wall Design Report- Eurocode 2-2004 enhancement to report wall unbraced height used for computing pier buckling load capacity.
- Material Library - Russian material library updated.
- Slab/Beam Design - CSA S16-09 and CSA S16-14 enhancement limiting the total effective width of the slab to 1/4 the span of the beam and taking in account the amount of deflection caused by shrinkage of the concrete.
Output and Display
- Database tables reporting story and diaphragm maximum and average drifts.
- Drifts now reported at brace locations.
External Import/Export
- Export of AutoCAD .dwg files for AutoCAD versions 2015 and 2016 now available.
Enhanced Application Programming Interface (API)
- Plugins written to access API (Application Programming Interface) now accessible within ETAB
[-] The following 5 users say Thank You to TAFATNEB for this post:
  • oanm2000, caifan, PinkPant, Dell_Brett, bigone
ETABS 2015 15.2.2 Build 1364
Release Notes:
LINK CODE PROTECTED
New Key Generator for 15.2.2 version up to July 2017.
Thanks to LAVteam.
Use the forum standard password.
ETABS 2016, v16.0
Stability is the best policy.
[-] The following 20 users say Thank You to Arigato for this post:
  • highcivil, Dell_Brett, RajaK, cace-01, miquan, golpesar, Rodmo376, MOSS2000, oanm2000, milvio, titko, SThirapat, mgdario, betinnn, bridgeengineer, simanta, TAFATNEB, PinkPant, tentaeste, learner20
ETABS 2016, v16.0 X32 (Setup file):
No limits to creativity
[-] The following 23 users say Thank You to joker™ for this post:
  • RajaK, miquan, learner20, KhaLed-S.E, Jackass, oanm2000, MOSS2000, milvio, titko, Dell_Brett, SThirapat, betinnn, slowet, 7.85, civilgen, bridgeengineer, kirankumarklk, simanta, TAFATNEB, PinkPant, jcbv, ESTRUCTO, tentaeste
updated new version, v16.01
fixed some bugs in PBD
dl links:
[-] The following 14 users say Thank You to Arigato for this post:
  • zrilek, oanm2000, PinkPant, temp1366, rezart, KhaLed-S.E, jorgeramos, malc, Dell_Brett, macrem99, cace-01, faros3000, albani, mgdario
CSI ETABS 2015 v15.2.0.1295 (x64) PinkPant 1 2,684 03-09-2016, 10:51 PM
Last Post: ALMF
ETABS 2015 V15.0.0 aslam 17 21,683 08-26-2015, 06:00 PM
Last Post: er.shyams
