AISC_2015 NASCC Presentations videos
2015 NASCC Presentations - March 25-27 - Nashville
[Image: 17319716151355340178.jpg]
  • Publisher: AISC
  • Year: 2015
  • Language: English
  • Size: !! Large enough GB
  • Quality: HD 720
Online Conference Proceedings
ID Title Speaker(s)
B1 Bridges of the Volunteer State Edward Wasserman, Wayne Seger
B2 Award-Winning Bridge Projects in Steel Jason Fuller, Jack R. Haynes, Will Watts
B3 Fracture Critical Determination: Current and Future Practice, Part 1 Denis Mertz, Justin Ocel
B4 Fracture Critical Determination: Current and Future Practice, Part 2 Robert Connor, John Holt
B5 Long-Term Performance of Steel Bridges Jennifer Righman McConnell, Phil Lewis
B6 High-Performance Steel Bridge coating Options Robert Kogler
B7 Topics on Fabrication and Inspection of Steel Bridges Mark Bowman, Heather Gilmer
B8 Behavior of Skewed and Curved Steel I-Girder Bridges Ronnie Medlock, Michael Grubb
B9 Steel Bridge Fabrication - Improving the State of the Art Mark Davis, Steve Duke, Karl Frank
B10 New Structural Forms for Short-Span Bridge Applications Gregory K. Michaelson, Atorod Azizinamini, Doug Davis
C1 Shop Drawings: Success & Failure - A Standard Procedure is Not Right for Every Project Michael L. Sterling
E1 Teaching Bridge Design David E. Greifzu, Ted Zoli
E2 Looking Forward: Career Insights from Industry Professionals Erleen Hatfield, Andrew Hermiz, John Kennedy, Allan Olson
F1 Next Generation Steel: USACE's Fort Benning Hospital Luis V. Posada Jr. Zachary Kates, Martin Miller, Jay Allen
F2 Tools for Fabricators Participating in Federal Projects Whitney Debardeleben Jr. Angela R. Stephens, John Saul, Blake Hokisson
F3 GSA Design Excellence 101 Leslie Sheperd
F4 Beyond Blast Kevin Rodney, Lucas Nisley, Michael Pittsman, Peggy Van Eeopel, Theresa Sheils
G1 Innovative Collapse Prevention for Seismic Effects Finley A. Charney
G2 Part 1: Seismic Design for Non-West Coast Engineers Michael Engelhardt
G3 Part 2: Seismic Design for Non-West Coast Engineers Michael Engelhardt
G5 90 Seismic Design Ideas in 90 Minutes James Malley, Rafael Sabelli, Pat Hassett
G6 Current Views from Past Higgins Award Winners: Jerry Hajjar Jerome Hajjar
G7 K Frame No More: BRBF procedures for Multi-Tier Braced Frames Kimberly Robinson, Robert Tremblay
G8 AISC Research: Protecting the Protected Zone Matt Eatherton
N1 Weld Details-Good, Bad & Ugly Duane Miller
N2 Stability Design of Steel Buildings Lawrence G. Griffs, Donald W. White
N3 Current Developments in the AISC Code of Standard Practice Charles Carter
N4 Alternate Methods to Connection Design Patrick McManus, Larry Mui
N5 Blown Away: Arc Flash Safety Scott Mitchell
N6 What Makes a Good Design Drawing? Rob Schoen, Darren Hartman
N7 Detailing for Constructability---A Lost Art? Don Engler, Chris Fischer
N8 IMPACT, The New Business Model for the Ironworker Contractor Mark Thomas, David Hunt
N9 Paperless Ironworker Harvey Swift
N10 Working with Large Trusses Sylvie Boulanger, Collin Hughes
N11 Follow the Load Path to Avoid Unfortunate Consequences Carol Drucker
N12 Emerging Technology for the Fabricator, Erector and Detailer Jacob Thomas
N13 Current Development in the Bolt Spec Allen Harrold
N15 Lessons I Wish I Had Known Starting Out Kara Hendren, Matthew Streigd, Kieran Kelly-Sneed, Brittany Salmon, Jie Zou
N16 Are the Results of My First or Second-Order Analysis Correct? Is It Me or the Software? Joshua Buckholt
N17 Innovative Manufacturing of Conical Steel Tubular Towers supporting Wind Turbines Andrew Myers, Eric Smith
N18 The Direct Analysis Method---Nothing but Examples! Gabriel A. Jimenez
N19 Interactive Steel Quiz Larry Muir, Carlo Lini
N20 Mathcad Hand Tools - Part 1 Brent Maxfield
N21 Mathcad Hand Tools - Part 2 Brent Maxfield
N22 Connections: Simple, Complex and Perplexing William W. Merrell
N23 Safety: Beyond OSHA Minimums Wayne J. Creasap II
N24 AISC Research: Beam-Column Bracing (Strength and Stiffness) Don White
N26 Sustainability 2015: What's New with Steel and Sustainability John Cross
N27 Typical Practice for Atypical (Non-Uniform) Loads on Steel Joists Tim Holtermann
N28 Flexible Moment Connections Clinton O. Rex
N29 Recent Developments in Design for Ponding Arvind V. Goverdhan, J.R. Ubejd Mujagic
N30 The Art of Structural Drafting—Tips for Producing High-Quality Structural Drawings The Art of Structural Drafting-Tips for Producing High-Quality Structural Drawings
N31 Achieving Economical Long Spans with Composite Truss Construction David Stevenson, Tim Verhey
N32 HSS Design: New Codes and Material Specifications Kim Olson
N33 Orchestrating the Nashville Music City Center Steel Frame Bill Hanson, Jason Turk
N34 Your Life Is on the Line? Best Practices for Selection, Design and Use of Horizontal Lifeline Systems Greg Small
N35 Pre-Planning Tips & Tools Steve Burkholder
N36 What's Wrong with This Picture? John C. Schuepbach
N37 Design and Stability of Connection Elements Bo Dowswell
N38 Future Directions in Designing Bridging for Open-Web Steel Joists Ron Zeimian, Tim Holtermann
N39 Effective Use of the New SDI Roof Deck Design Manual Thomas Sputo, Michael Martignetti, Mike Antici
N40 Learn the Tricks to Designing Joist Girder Moment Connections James M. Fisher
N41 Casting Your Future David Poweleit, Raymond Monroe
N42 Metal Versus Metal—Who Wins the Corrosion Battle? Thomas J. Langill
N43 Roof and Floor Deck Diaphragms: Behavior and Design W. Samuel Easterling
N44 Engineers: Getting the Welds You Want and Need Robert E. Shaw
N45 Birth of the Steel Skyscraper Benjamin W. Schafer
N46 Of Course It's Right, It Was Done by a Computer! Mark Sencich, Kenny Rowell
N47 What is the NISD? Fred Tinker, David Merrifield, John Linn, Jack Metcalf, Joel Hicks
N48 All Detailers Are Not Created Equal Alden Prier
N49 Best Coating Practices---How to Avoid Coating Failures Rich Burgess
N50 Vertical Bracing Connections-Analysis and Design William A. Thornton, Larry Muir
N51 Sustainability 2015: Understanding Life cycle Assessments Brandie Seebastian, Mark Thomas, John Cross
Q1 So You Want to Be AISC Certified? Todd Alwood, Lisa Patel
Q2 Quality Manuals! Where Do I Begin? John Sedlak
Q3 What is the Real Value of a Quality Management System? Todd Alwood, Chris Crosby
Q4 Quality and the Small Business Owner Jake Thomas, Billy Witcofski, Babette Freund
Q5 Stats + Quality = Increased Overall Production Lawrence Kruth, Mark Trimble, Bob Zaykoski
Q6 How Do I Prepare for My Next AISC Audit? Lee Patza
Q7 Updates to the AISC Erector Certification Program Lisa Patel, Larry Martoff
Q9 Demystifying Chapter N and the Building Code-What Every Fabricator and Erector Needs to Know Larry F. Kruth
S1 Stability of Cold Formed Members Todd Helwig
S2 Topics in Structural Stability Research Benjamin W. Schafer
S3 Stability Under Seismic Loading Conditions Clarence Miller
S4 Stability of Steel Bridge Systems Peter Birkemoe
S5 Stability at High Temperature Conditions Donald W. White
S6 Stability of Wall Systems and Diaphragm Braced Beams Perry S. Green
S7 Stability Bracing Dinar Camotim
S8 Stability of Web Tapered Members and Castellated Beams Leroy Lutz
S9 Beedle Presentation Session: David A. Nethercot Benjamin W. Schafer
S10 Stability of Angles, Channels and Z-Shaped Members Donald Sherman
S11 Stability of Hollow Sections Ronald D. Ziemian
T1 AISC BIMSteel Initiatives Luke Faulkner
T2 An Intelligent Future: Following the 2%ers Chris Moor
T3 State of Technology Brian Cobb, Luis Torres
T4 Will Technology Change Our Business Models? Part 1: Identifying the Challenges Brian Cobb, Rob Schoen, Sean Smith, Doug Fitzpatrick, Mark Hollan, Wayne Morrison
T5 Will Technology Change Our Business Models? Part 2: Debating the Solutions Brian Cobb, Rob Schoen, Sean Smith, Doug Fitzpatrick, Mark Hollan, Wayne Morrison
T6 steelXML-Changing the Way We Buy Steel Forever Matthew Gomez
T7 Managing Steel Production with a Single Data File Chris Moor
T8 Lean Steel-Applying Lean Thinking to the Structural Steel Project Delivery Process Stephen Bluemenbaum, PE, Mark Waggoner, PE, Ryan Seckinger
T9 Lean Methodology-A Primer on Lean Manufacturing Chris Moor
T10 Improving Project Coordination through Innovation: Reaching LOD 500 on Large Capital Projects Paul Nunn
Z1 Common Business Development Challenges Susan C. Smith
Z2 The Business Case for Integrated Lean Project Delivery Howard Ashcroft Jr., David Hagan, Jason Collins
Z3 Legal Primer for Project Managers David Ratterman
Z4 Conflict Management & Negotiation C.J. Larkin
Z5 The Art and Science of Successful Meetings Mike West
Z6 Risk Management in Today's World (or Lack Thereof) William Barger
Z7 The GC Perspective on the Impact of Project Delivery Method Greg Mulac
Z8 Getting Paid for Extra Work-How to Avoid the "Black Hole of Change Orders" Terry L. Salazar
Z9 The Construction Market-Where to From Here? John Cross
[-] The following 12 users say Thank You to bigone for this post:
  • atram, ting tsai huang, eng donny, oanm2000, K.Lee, psk62, malc, jcbv, araza023, ykhackhack, PinkPant, moh_towhid
AISC_2014 NASCC Presentations videos bigone 0 4,915 09-25-2014, 09:23 AM
Last Post: bigone
Some AISC NASCC Presentations videos RyanRS 6 5,952 08-19-2014, 03:42 PM
Last Post: vishal
AISC_2013 NASCC Presentations videos bigone 0 3,373 09-09-2013, 11:49 AM
Last Post: bigone
