The Design of Vibro Replacement
Author: Heinz J. Priebe | Size: 292 KB | Format: PDF | Quality: Unspecified | Year: 1995 | pages: 17
[Image: 07903703816877561462.jpg]
Vibro Replacement is an accepted method for subsoil improvement, at which large-sized columns of coarse backfill material are installed in the soil by means of special depth vibrators. The performance of this composite system consisting of stone columns and soil, is not determinable by simple investigation methods like soundings, and therefore, such methods are not suitable for design purposes. However, theoretically, the efficiency of Vibro Replacement can be reliably evaluated. The method elaborated on a theoretical basis and described in this contribution, is easy to survey and adaptable to different conditions due to the separate consideration of significant parameters. Practically, it comprises design criteria for all frequently occurring applications.
PinkPant
[-] The following 13 users say Thank You to PinkPant for this post:
  • blaze, cace-01, uetian19, oanm2000, zrilek, Jackass, gulilero, dizz, jfjdm, ykhackhack, amindoxiti, 3fan, oreslaw
The Design of Vibro Replacement - The application of Priebe's method to extremly soft soils, "floating" foundations and proof against slope or embankment failure
DIRECT LINKS thumbup
[-] The following 8 users say Thank You to 3fan for this post:
  • PinkPant, Dell_Brett, oanm2000, cace-01, geomahesh, zrilek, malc, oreslaw
Could you please kindly re-upload the document from post #2 as the link no longer work?
it work's. try harder
[-] The following 3 users say Thank You to zrilek for this post:
  • Dell_Brett, 3fan, oanm2000
Design of Vibro Replacement shadabg 0 1,227 09-15-2012, 07:49 AM
Last Post: shadabg
