Civil Engineering Association eBooks Water & Hydraulic Engineering Matrix Method for Analysis of Hydraulic Networks
 Dobblo
South Africa
User ID: 44024
Threads: 6
Likes: 319 in 31 posts
Given Likes: 43
Points:2,790 EP
04-15-2015, 06:15 PM (This post was last modified: 04-15-2015, 06:16 PM by Dobblo.)
Author: Amir N. Nahavandi, George V. Catanzaro | Size: 3.06 MB | Format: PDF | Quality: Scanner | Publisher: ASCE Journal of the Hydraulics Division | Year: January 1973 | pages: 18 | ISBN: 0044796X
[Image: 62661356508213511848.jpg]
A new matrix method is developed for the steady-state and transient analyses of incompressible flow networks. It is shown that the branch pressure drop versus nodal pressure, nodal continuity, and branch momentum equations can be expressed in matrix form for networks with any arbitrary configuration. These equations are solved simultaneously to obtain explicit relations for the unknown nodal pressures and branch mass flow rates. This new technique is applied to the analysis of a water distribution network. To ascertain the accuracy of the solution, a numerical stability and convergence analysis is performed which provides an estimate for the upper bound of time increment needed for a stable and convergent numerical integration. The transient and steady-state behavior of incompressible flow networks with arbitrary configurations having nodal sources and sinks as well as branch transducers are determined by the time-integration of the network dynamic equations with a comparatively smaller computer running time.
[-] The following 3 users Like Dobblo's post:3 users Like Dobblo's post
  • oanm2000, PinkPant, emmi
  Design of Water Supply Pipe Networks raffah 8 14,788 05-25-2024, 11:08 AM
  Hydraulic Analysis of Unsteady Flow in Pipe Networks febo927 0 1,869 09-14-2018, 12:37 PM
Last Post: febo927
  Neural Networks and Sea Time Series ska51 0 1,211 11-17-2011, 01:29 PM
Last Post: ska51
  Neural Networks for Hydrological Modeling ska51 1 1,693 09-01-2010, 01:29 PM
Last Post: leoncito
