ETABS 2013 V13.2.0
Etabs 2013 V 13.1.2 32&64 Bit
ETABS 2013 13.1.2 Enhancements Subscribe RSS
Significant enhancements included in ETABS 2013 v13.1.2:
Concrete frame design and shear wall design using the AS 3600-09/NZS 3101-06 codes have been updated for Amendment No. 3 in 2011 affecting the seismic load combinations.
Multiple enhancements have been made to shear wall design using the Eurocode 2-2004 code for the uniform-reinforcing and section-designer section options.
The output table Modal Direction Factors, primarily used for Chinese design, has been enhanced to include the contribution of all mass in the structure, not just the mass in rigid diaphragm constraints.
Database tables can now be exported to an XML file that can be opened by Microsoft Access, allowing the export to Access on machines that do not have it installed.
The loads from staged-construction load cases can now be exported to SAFE.
Multiple enhancements have been made to the import of .DXF files for floor plans, 3D models, and grid systems.
Multiple enhancements have been made to the import and export of IFC 4 files.
Multiple enhancements have been made to the import of SDNF files.
Multiple enhancements have been made to the import of CIS/2 files.
Many additional Open API functions have been implemented.
[Image: comments.png]
MIRROR OF POST #2 - 365 DAYS LICENSE
Las estructuras no trabajan como se calculan !! trabajan como se construyen !!
[-] The following 9 users say Thank You to axcel for this post:
  • giga, Visitante, ashcivilea, zrilek, mgdario, bigone, ykhackhack, yly8, ting tsai huang
Next user writing here (software product thread) about the not working license will receive a warning for spam. I deleted enough posts about (including two of VIP members) and if you can't remember where to post software problems the warning will help to refresh your memory. The user with the post including the license link is requested to provide a proof or to ask a moderator to delete the link.
[-] The following 17 users say Thank You to BennyP for this post:
  • Visitante, learner20, zipatton, LiviuM, oanm2000, Williams, aslam, ssobhan, cace-01, tarugo, chandra1234567, TAFATNEB, MOSS2000, milvio, bigone, Mohammad6299, HofOblivion
This one works.
Forum Password as usual.
No image because the pic server doesn't work but this key generator make a license working in CSI Etabs 2013 V13.1.2, in CSI SAP2000 v16.0.2 and in CSI Bridge 2014 v16.0.1.
Etabs 13.1.2 License Generator
- only crack
- not tested yet
[-] The following 27 users say Thank You to mowafi3m for this post:
  • learner20, malc, Rainbow, Jackass, ssobhan, blaze, chenamoy, Andrew seah, MOSS2000, hatkam, mahyarov, bigone, caraiane, axcel, zrilek, pezhmankhan, Dell_Brett, yamacdere, nickycruz, pram, narendra, Rodmo376, oreslaw, levanduy, yly8, pmav99, tang1942
CSi License Generator 2013+Help
[Image: 65561181331019827363.png]
CSI ETABS 2013 V13.1.3 setup only
from LAVteam
32 bit
64bit
[-] The following 25 users say Thank You to bigone for this post:
  • blaze, Williams, Diquan, nickycruz, malc, jaxdes, nowanda, axcel, MOSS2000, chenamoy, TAFATNEB, SCREAM7890, oreslaw, rendel_©, Visitante, napeera, yly8, slowet, Andrew seah, ting tsai huang, Rami11, araza023, draluka, narendra, salahcivil
CSi License Generator 2013 in Post#7 is working for CSI ETABS 2013 V13.1.3
if you already installed Etabs 13.1.2 on your machine and used CSi License Generator 2013 in Post#7 - just install Etabs 13.1.3 -
[Image: 30065209127144983744.png]
[-] The following 18 users say Thank You to bigone for this post:
  • mowafi3m, Dell_Brett, milvio, zrilek, Williams, Diquan, ykhackhack, nickycruz, jaxdes, oyabun, TAFATNEB, Visitante, taifur, yly8, amiboyz, Andrew seah, deovratk, Mohammad6299
p@ssword:
[-] The following 8 users say Thank You to andersen3 for this post:
  • narendra, smode, Dell_Brett, bigone, oreslaw, ali akbar, ting tsai huang, Mohammad6299
CSI ETABS 2013 version 13.1.3 Build 1065 TAFATNEB 1 4,775 11-30-2013, 09:32 PM
ETABS 2013 V13.1.1 asumi 12 17,039 09-12-2013, 04:36 AM
Last Post: engiman27
