strukts Excel Sheets according ACI318-08
Author: strukts | Size: 6.94 MB | Format: xls | Quality: Original preprint | Publisher: strukts
[Image: 37424672521471441399.png]
[Image: 93510268602225830655.gif]
strukts spreadsheets introduces the best and most powerful and stable structural design spreadsheets on the internet. The main criteria behind strukts spreadsheets is to allow the engineer to design any number of cross sections in one click by filling the necessary fields in each row representing a section to be designed and get the results beside each section without the need to scroll up and down and designed to reduce the number of human errors to ZERO. No more incorrect inputs. Just focus on the advanced part of your structure and leave the design for strukts spreadsheets. How?!
Through the simple interface, you can just insert your data or;
Export the analysis results from any FEM software and paste them in a new workbook.
Link the rows to the input table.
Rename the sections field as you wish.
Press on Solve button to solve all the sections or load cases inserted.
Press on Solve selection button if you wish to study a particular section by moving to the desired section and clicking on the button.
Press on Print all button to print all sections in individual calculations sheets as you have created them one by one with no errors or mistakes.
Press on Print selection button if you wish to have a printout from a particular section.
Have up to 1000 cross sections solved and printed in few clicks. Even more with the paid versions!
All the project’s data can be saved in one spreadsheet Or can be categorized as you wish.
Allowable sheets for download:
1-ACI318-08 isolated Footings
2-ACI318-08 rectangular column
3-Modulus of subgrade reaction
4-ACI318-08 Flexure
5-ASCE7-05 Wind analysis
6-ACI318-08 Beams
7-ACI318-08_shear
8-ACI318-08 Circular column
9-ACI318-08 Punching shear
10-Deflection
STRUKTS presentation
[Image: comments.png]
sheets is Editing password protected
[-] The following 11 users say Thank You to bigone for this post:
  • hatkam, ting tsai huang, dinu69in, bridgeengineer, Hengki, Andrew seah, mohcivil, MOSS2000, learner20, harsono, ali akbar
437+ Civil Engineering Excel Sheets imran 10 49,141 05-19-2017, 11:48 PM
Last Post: joker™
miscellaneous Excel sheets mowafi3m 6 10,040 11-21-2016, 04:40 PM
Last Post: mowafi3m
