Limit State of the Plate Elements of Steel Structures
Author: J. Djubek , R. Kodnar , M. Skaloud | Size: 6 MB | Format: PDF | Quality: Unspecified | Publisher: Birkhäuser | Year: 1983 | pages: 296 | ISBN: 3034874995 ISBN13: 9783034874991
[Image: 21249165459445421106.jpg]
The necessity to save steel leads to a marked tendency towards thin-walled structures. Such structures are made of thin plating, the behaviour - and, of course, design - of which is very significantly affected by stability phenomena. In fact, with up-to-date thin-walled steel plated structures, it is very frequently the point of view of stability that governs the design. So it is not astonishing that the attention of a great number of research teams in various parts of the world has been for a good many years directed to investigations into numerous aspects of the buckling behaviour of steel plated structures. However, the current problems of buckling research, which require to account for the effect of initial imperfections, post-buckled behaviour and plastic reserve of strength (this leading in theoretical research to the necessity to solve boundary value problems of geometrically and physically non-linear partial differential equations, and in experimental studies to conduct experiments on full-size test girders) are very complex and time-consuming. Then it is beyond the means of one investigator, or even of one research team, to deal successfully with such problems and, conse­ quently, effective cooperation is indispensable. This was also the reason for the initiation of a fruitful collaboration between the first author of this book (Assoc. Prof. J. Djubek, D. Sc. ) and the third author (Assoc. Prof. M. Skaloud, D. Sc.
[-] The following 15 users say Thank You to amindoxiti for this post:
  • apocalipse, zrilek, Mohammad6299, cace-01, warlord1, malc, gulilero, englandboy, bridgeengineer, subin91, PinkPant, oanm2000, jcbv, knrsa, cristi
Structural Plasticity: Limit, Shakedown and Dynamic Plastic Analyses of Structures rusty 7 5,429 06-28-2018, 04:13 PM
Last Post: febo927
Direct Methods for Limit and Shakedown Analysis of Structures cace-01 2 2,289 04-18-2016, 01:43 AM
Direct Methods for Limit States in Structures and Materials cace-01 2 2,180 05-23-2014, 08:26 PM
Last Post: cace-01
Limit States of Materials and Structures: Direct Methods ir_71 1 1,936 03-20-2014, 12:01 PM
plate and shell elements preceptor 1 2,912 01-24-2013, 09:27 AM
Last Post: LiviuM
