Plastic Theory of Structures
Author: Michael R. Horne | Size: 11 MB | Format: PDF | Quality: Scanner | Publisher: PERGAMON INTERNATIONAL LIBRARY | Year: 1979 | pages: 177
"The plastic theory of structures," the author writes, "is an essential complement to elastic theory. The readily applied forms of either theory depend on idealized mathematical models both of the material properties and of the fabricated nature of the structure. By applying each theory in turn to the same structure, a much better overall picture is obtained of the stability, rigidity, and strength than is possible by applying either theory on its own."
Plastic theory is used as the basis of design for the majority of single-story rigid frames and is being increasingly applied to multistory frames. An important feature of the theory is the extent to which intuitive ideas of structural behavior may be used to solve problems. In this text, Professor Horne employs this method to explain the principles involved. He backs up the intuitive approach by formal statements and proofs of theorems and explains the methods of plastic analysis. Methods which are of value in design applications and are suited primarily to hand calculations are emphasized, but methods suitable for computer application are also included. Relevant problems are given at the end of each chapter with answers at the end of the book.
[-] The following 20 users say Thank You to apocalipse for this post:
  • Jackass, bridgeengineer, dinu69in, zrilek, cace-01, blaze, ssobhan, Mohammad6299, ykhackhack, f_slikken, malc, gulilero, subin91, oanm2000, Dell_Brett, PinkPant, mgdario, cristi, amindoxiti, devilmaycry
[-] The following 9 users say Thank You to r3be1 for this post:
  • knrsa, devilmaycry, warlord1, jcbv, oanm2000, gulilero, bridgeengineer, hodzicemir, Mohammad6299
Plastic Methods for Steel and Concrete Structures amindoxiti 3 3,273 02-12-2019, 07:18 PM
Last Post: carolinandra
Structural Plasticity: Limit, Shakedown and Dynamic Plastic Analyses of Structures rusty 7 5,429 06-28-2018, 04:13 PM
Last Post: febo927
Shakedown of Elastic-Plastic Structures - 1st Edition febo927 0 540 06-28-2018, 03:47 PM
Last Post: febo927
Performance based plastic design of earthquake resistant steel structures sabooryan 1 1,543 09-14-2017, 09:53 AM
Simplified Theory of Plastic Zones KhaLed-S.E 2 2,716 09-09-2016, 10:53 AM
Last Post: ssobhan
