The following Enhancements have been implemented for CSiBridge 2015 v17.0.0:
The responsiveness of the user interface has been improved.
The DirectX graphics functionality has been enhanced.
A friction-spring hysteretic damper has been implemented as a new link property. The force-displacement relationship exhibits linear slipping stiffness when loading, but unloads with a smaller slipping stiffness. A pre-compression displacement and a displacement stop-limit may be specified.
A bilinear Maxwell damper has been implemented as a new link property. This device is a linear spring in series with a dashpot whose force-velocity relationship exhibits bilinear viscous behavior, typical of certain oil dampers having a relief valve.
Improved convergence behavior and increased speed for nonlinear static and direct-integration time-history analysis.
Increased speed of moving load analysis by parallelization.
Superstructure design checking has been extended to include composite bridge superstructures with steel U-girders according to the Canadian CAN/CSA-S6-06 code.
Superstructure design checking has been extended to include composite bridge superstructures with steel U-girders according to the Indian IRC-2011 code.
Superstructure design checking has been implemented for concrete superstructure sections according to the Russian SNiP 2.05.03-84 code. Superstructure types supported include prestressed concrete box girders and composite sections with precast I-girders and U-girders.
Superstructure design reports have been enhanced to include step-by-step detailed output, including equations and code references. These are currently available for AASHTO LRFD 2007 and 2012, for multi-cell concrete box shear and flexure checks and precast composite I-beam shear and flexure checks.
A traditional menu has been added as an alternative to the ribbon. Users can switch between the two options.
The ribbon style has been updated to be similar to current Microsoft applications.
Other minor enhancements.
08-07-2014, 10:46 PM (This post was last modified: 08-07-2014, 10:47 PM by jamesmakeez. Edit Reason: )
CSi Bridge 2015 Keygen
Confirmed Keygen for 2014 works for CSi Bridge 2015. (As it did for SAP2000 v17)
09-04-2014, 05:13 PM (This post was last modified: 09-04-2014, 05:14 PM by aslam. Edit Reason: )
CSI BRIDGE 2015 v17.1.0
CSiBridge 2015 Enhancements
The old KG works giving 117 days (you know how to extend using
The new of Lavteam give 317 days but is identified as virus (at least by my Antivirus). Disable it for a few minutes. The same generated license works in SAP2000 too.
10-02-2014, 06:03 PM (This post was last modified: 10-02-2014, 06:04 PM by Jackass. Edit Reason: )
Hi
CSI Bridge 15 v17.1.1
10-05-2014, 11:18 AM (This post was last modified: 10-05-2014, 01:31 PM by Dell_Brett. Edit Reason: )
new csi license generator
This keygen is the same as LT forum.
Some antivirus detects a virus (ESET SMART SECURITY and others). It's a FALSE POSITIVE.
But, use at your own risk!
Modeling, analysis and design of bridge structures have been integrated into CSI Bridge to create the ultimate in computerized engineering tools. The ease with which all of these tasks can be accomplished makes CSI Bridge the most versatile and productive software program available on the market today.
Using CSI Bridge, engineers can easily define complex bridge geometries, boundary conditions and load cases. The bridge models are defined parametrically, using terms that are familiar to bridge engineers such as layout lines, spans, bearings, abutments, bents, hinges and post-tensioning. The software creates spine, shell or solid object models that update automatically as the bridge definition parameters are changed.
CSI Bridge design allows for quick and easy design and retrofitting of steel and concrete bridges. The parametric modeler allows the user to build simple or complex bridge models and to make changes efficiently while maintaining total control over the design process. Lanes and vehicles can be defined quickly and include width effects. Simple and practical Gantt charts are available to simulate modeling of construction sequences and scheduling.
CSI Bridge includes an easy to follow wizard that outlines the steps necessary to create a bridge model.
Bridge2015 17.2 License (including for SAP2000 17.2)
Curtesy of Lavteam
7.Don't use REPLY if no need, use New Reply. Chatting not allowed.
