NCMA Research Reports
NCMA research reports
Author: NCMA | Size: 87.1 MB | Format: PDF | Quality: Original preprint | Publisher: NCMA | Year: 2014 | pages: MULTIPLE PDF
[Image: 85794401462734713443.jpg]
Research Reports from NCMA
LIST OF CONTENTS
FR01: Spacing of Reinforcing Bars in Partially Grouted Masonry
FR02: Water Penetration Testing of Stucco on Concrete Masonry Construction
FR03: Resistance of Multi-Wythe Insulated Masonry Walls Subjected to Impulse Loads (Volume 1)
Impact Testing Video - Concrete Masonry Construction
MR07: Research Investigation of the Properties of Masonry Grout in Concrete Masonry
MR08: Research Evaluation of the Compressive Strength of in Situ Masonry
MR09: Research Evaluation of the Effect of Unit Configuration on the Compressive Strength of Solid Concrete Paver Units
MR10: Research Evaluation of the Flexural Tensile Strength of Concrete Masonry
MR11: The Effects of Concrete Masonry Unit Moisture Content on Grout Bond and Grout Compressive Strength
MR12: Evaluation of Minimum Reinforcing Bar Splice Criteria for Hollow Clay Brick and Hollow Concrete Block Masonry
MR13: Research Evaluation of Various Grout Consolidation Techniques in Concrete Masonry
MR14: An Investigation of the Performance of Walls with Exterior Insulation and Finish Systems (EFIS) in Three Climatic Regions of the
United States
MR15: Prison Wall Impact Investigation
MR16: Issues Affecting Color Durability in Concrete Masonry, Segmental Retaining Wall Units and Unit Concrete Pavers
MR18: Prison Wall Impact Investigation - Phase II
MR19: Evaluation of Paver Slab Freeze-Thaw Scaling Testing
MR20: Evaluation of Paver Slab Flexural Strength Testing
MR21: Investigation of Wind Projectile Resistance of Concrete Masonry Walls and Ceiling Panels with Wide Spaced Reinforcement for
Above Ground Shelters
MR23: Research Evaluation Potential: For Growth Of Mold/Fungi On Concrete Masonry Products
MR24: Investigation of Alternative Grouting Procedures in Concrete Masonry Construction Through Physical Evaluation and Quality
Assessment, Report of Phase I Research
MR25: Investigation of Alternative Grouting Procedures in Concrete Masonry Construction Through Physical Evaluation and Quality
Assessment. Report of Phase II Research
MR26: Effects of Confinement Reinforcement on Bar Splice Performance
MR27: Effects of Confinement Reinforcement on Bar Splice Performance - Phase II
MR29: Self-Consolidating Grout Investigation: Compressive Strength, Shear Bond, Consolidation and Flow
MR30: Research Evaluation of the Effects of Concrete Masonry Structural Cover Over Spliced Reinforcing Bars
MR31: Self-Consolidating Grout Investigation: Making and Testing Prototype SCG Mix Designs - Report of Phase II Research
MR32: Effects of Confinement Reinforcement on Bar Splice Performance - Phase III
MR33: Effects of Confinement Reinforcement on Bar Splice Performance Summary of Research and Design Recommendations
MR34: Research Evaluation of the Effects of Concrete Masonry Structural Cover Over Continuous Reinforcing Bars
MR35: Report on Full Scale SRW Test Walls
MR35S: Full Scale SRW Testing Report Summary
MR36: Assessment of the Effectiveness of Water Repellents and Other Surface Coatings on Reducing the Air Permeance of Single Wythe
Concrete Masonry Assemblies
MR37: Recalibration of the Unit Strength Method for Verifying Compliance with the Specified Compressive Strength of Concrete Masonry
[Image: comments.png]
Best Regards
[-] The following 4 users say Thank You to malc for this post:
  • ykhackhack, Mohammad6299, PinkPant, blaze
