Autodesk AutoCAD Raster Design 2015
Current time: 02-18-2018, 07:25 PM
Author: BennyP
Replies 0
Views 2134
[Image: 21303352665516126463.gif]
[Image: 58270963932035874823.gif]
[Image: 25085015295710791406.gif]
AutoCAD Raster Design allows you to effectively use scanned paper drawings, aerial photographs, digital elevation models (DEM) and satellite data inside your AutoCAD® drawings. You can insert bitonal, grayscale, and color raster images into your AutoCAD drawings, then correlate, edit, analyze, and export the results.
AutoCAD Raster Design can analyze and display image data from a wide range of sources, including satellite imagery, wavelet compressed images, and digital elevation models (DEM). AutoCAD Raster Design also provides efficient tools for cleaning up and archiving paper-based drawings in digital form.
  • Dell_Brett, kamran, zrilek
Autodesk AutoCAD 2015 (x86/x64) BennyP 4 7,941 06-01-2017, 03:40 PM
Last Post: lesgiu
Autodesk AutoCAD Raster Design 2018 BennyP 0 682 03-24-2017, 07:40 AM
AutoCAD Raster Design 2017 temp1366 1 878 03-28-2016, 07:37 PM
Autodesk Revit Extensions 2015 KhaLed-S.E 0 1,413 03-28-2015, 09:53 AM
Last Post: KhaLed-S.E
Autodesk AutoCAD 2015 Service Pack 2 rami1976 0 1,435 03-22-2015, 06:16 PM
