Bentley Geotechnical Software 2014 version 17.00.28.00
Current time: 09-19-2018, 08:31 AM
Author: BennyP
Last Post: fixxxer0
Replies 2
Views 5099
[Image: 50620550015497378261.jpg]
Today we have some problem with the new uploaded images in server.
GeoStructural Analysis (GSA) is a comprehensive integrated suite that addresses a wide range of geotechnical and analysis challenges including shoring excavation, retaining walls, foundation, settlement, slope stability, tunnels, pilling, and more.
The integrated modules share a common workflow that allows easy review of alternate designs that conform to industry standards and specifications, as well as analysis by discrete construction stages, various analysis scenarios, or evaluation of analytical solution versus Finite Element Method (FEM) solution of the same geotechnical problem.
Bentley's geotechnical software is designed by experienced engineers who fully understand the standards and requirements that facilitate high-quality data management, reporting, and analysis in the industry.
Bentley provides the following geotechnical design & analysis offerings.
- Bentley GeoStructural Analysis
Bentley's GeoStructural Analysis suite includes Excavation Analysis, Foundation Analysis, and Retaining Wall Analysis listed below, plus the following: Rock Stability, Ground Loss, Settlement, Task Manager
- Bentley GeoStructural Excavation Analysis
GeoStructural Excavation Analysis suite is designed to address analysis of excavation and retaining walls. It is most suitable and the most important suite for small companies. It consists of the following programs; Earth Pressures, Sheeting Design, Sheeting Check, Slope Stability
- Bentley GeoStructural Finite Element Analysis
The GeoStructural Finite Element Analysis suite contains tools for performing Finite Element modeling for a range of geotechnical problems including excavation, slope stability, foundation beams, settlement, tunneling, and more.
- Bentley GeoStructural Foundation Analysis
GeoStructural Analysis Foundation design modules enable users to quickly and easily develop sophisticated scenarios to facilitate designing, testing, and optimizing different foundations.
- Bentley GeoStructural Retaining Wall Analysis
GeoStructural Analysis provides a complete range of modules to develop in-depth, accurate, and fail-proof designs for all types of retaining wall structures (abutment, nailed slopes, cantilever, gabion and gravity walls, etc.).
[Image: comments.png]
[-] The following 31 users say Thank You to BennyP for this post:
  • hazus, Petrit, oanm2000, zrilek, Mohammad6299, Dell_Brett, emmi, dquan373, huy2009, Gabemzaman, shadabg, rigid_joint, bigone, Munykong, daywalker, PinkPant, serhioSPA, ELAHI1979, 2824, hatkam, dalejogb, mary, utan, Rami11, xdesi, 3fan, ssobhan, fordcell, Andrew seah, blaze, zinousoft
[-] The following 12 users say Thank You to al_frd for this post:
  • malc, ting tsai huang, oanm2000, mary, hatkam, bigone, jurrean, 3fan, Mohammad6299, viet2010, Andrew seah, rizal13
all links are dead.
lucky share pretends to look like it will work, but it does not.
[-] The following 2 users say Thank You to fixxxer0 for this post:
  • hatkam, conduite
Bentley GEOPAK Civil Engineering Suite V8i (Version 08.11.09.903 er.shyams 0 509 06-27-2018, 09:27 AM
Last Post: er.shyams
Bentley MSTower 06.20.01.09 build 02.07.2014 bigone 2 4,095 08-09-2015, 10:20 AM
Last Post: eng donny
Bentley Limcon v3.63.01.11 build 13.06.2014 bigone 2 7,362 04-24-2015, 03:04 PM
Last Post: bigone
BENTLEY STAAD.Foundation Version: 4.0 abudabeeja 0 2,591 06-24-2009, 11:34 AM
Last Post: abudabeeja
