SEISMIC PERFORMANCE ASSESSMENT OF NUCLEAR POWER PLANTS
Current time: 12-19-2018, 01:58 AM
Author: TAFATNEB
Replies 0
Views 1202
Author: Yin-Nan Huang , Andrew S. Whittaker and Nicolas Luco | Size: 152 KB | Format: PDF | Quality: Unspecified | Publisher: The 14 th World Conference on Earthquake Engineering October 12-17, 2008, Beijing, China | Year: 2008 | pages: 8
[Image: 13444809894269178432.png]
Seismic assessments of a sample conventional and base-isolated nuclear power plant (NPP) are performed using a new procedure that builds on the methodology presented in the draft ATC-58 Guidelines and the widely used Zion method, which uses fragility curves defined in terms of ground-motion parameters. The new procedure improves the Zion method by using fragility curves that are defined in terms of structural response parameters since damage and failure of NPP components are more closely tied to structural response parameters than to ground motion parameters. The proposed performance assessment procedure is used to
evaluate the mean annual probability of unacceptable performance of the sample NPP reactor buildings. The
seismic performance assessment confirms the utility of seismic isolation at reducing seismic risk in NPPs.
[-] The following 4 users say Thank You to TAFATNEB for this post:
  • malc, slowet, vardan, toa011
Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 5,737 08-01-2017, 10:19 AM
Last Post: abdulazizk
Performance-based seismic assessment of skewed bridges bridgeengineer 0 1,069 04-22-2016, 07:31 AM
Last Post: bridgeengineer
Assessment of the seismic performance of a bituminous faced rockfill dam Wolverine883 0 1,704 07-19-2015, 08:24 AM
Last Post: Wolverine883
Specialist Meeting on the Seismic Probabilistic Safety Assessment of Nuclear Faciliti TAFATNEB 0 836 08-10-2014, 02:26 PM
EXPERIMENTAL MULTI-LEVEL SEISMIC PERFORMANCE ASSESSMENT OF 3D RC FRAME DESIGNED FOR D TAFATNEB 0 1,050 06-03-2014, 10:01 PM
