RAM Structural System V8i Version: 14.05.04.00
Current time: 12-17-2018, 02:24 PM
Author: marion33
Replies 5
Views 8434
RAM Structural System V8i (Version: 14.05.04.00 Date: 9/12/2013)
The RAM Structural System is a specialized engineering software tool for the complete analysis, design, and drafting of both steel and concrete buildings. It optimizes workflows through the creation of a single model by providing specialized design functions for buildings and by providing thorough documentation.
RAM Structural System allows for the analysis and design of a building using a single model. The entire structure can be modeled, including decks, slabs, slab edges and openings, beams, columns, walls, braces, spread and continuous footings, and pile caps. This full structural model increases designer confidence and creates an efficient environment when dealing with changes.
The RAM Structural System increases productivity by performing the tedious and time-consuming functions specific to the design of a building such as calculation of live load reductions and lateral load calculations for wind and seismic. In addition, designs are optimized for both concrete and steel.
Your competitive advantage is realized with the thorough documentation. RAM Structural System automatically provides steel material takeoffs and detailed and summary reports of design calculations and drawings. And for BIM, RAM Structural System offers bidirectional integration with CADstudio and Bentley’s Structural Modeler, Structural Documentation Center, and Autodesk's Revit Structure.
[-] The following 15 users say Thank You to marion33 for this post:
  • zrilek, Williams, oanm2000, Rodmo376, shaker, nickycruz, narendra, promo8, ykhackhack, Visitante, Quantumm, bigone, Mohammad6299, shark, haze
Bentley RAM Structural System V8i v14.06.01.00
[Image: 27373541948088435827.jpg]
including Bentley RAM Concept V8i v05.01.01.10
The RAM Structural System is a specialized engineering software tool for the complete analysis, design, and drafting of both steel and concrete buildings. It optimizes workflows through the creation of a single model by providing specialized design functions for buildings and by providing thorough documentation. RAM Structural System allows for the analysis and design of a building using a single model. The entire structure can be modeled, including decks, slabs, slab edges and openings, beams, columns, walls, braces, spread and continuous footings, and pile caps. This full structural model increases designer confidence and creates an efficient environment when dealing with changes. The RAM Structural System increases productivity by performing the tedious and time-consuming functions specific to the design of a building such as calculation of live load reductions and lateral load calculations for wind and seismic. In addition, designs are optimized for both concrete and steel. Your competitive advantage is realized with the thorough documentation. RAM Structural System automatically provides steel material takeoffs and detailed and summary reports of design calculations and drawings. And for BIM, RAM Structural System offers bidirectional integration with CADstudio and Bentley’s Structural Modeler, Structural Documentation Center and Autodesk's Revit Structure.
RAM Concept lets structural engineers model, analyze, and design virtually any cast-in-place geometry, no matter how complex. Efficiency and quality control are realized through the advanced analysis and design tools for reinforced and post-tensioned concrete slabs and mats. Integration allows for analysis and design of a multi-story concrete structure therefore streamlining workflows.
[-] The following 23 users say Thank You to dl4all for this post:
  • ykhackhack, Albert, aslam, Quantumm, bigone, simanta, Visitante, nickycruz, andyspak2, oanm2000, cybermad, blaze, Ivan_1980, Mohammad6299, zrilek, jcbv, Dell_Brett, odiclas, pjcivil, mecheil.edwar, mohcivil, haze, lokitosamax
Mirror
Quote:Thanks to Original uploader.
use winrar 5 & forum password
@lahuta:
[-] The following 22 users say Thank You to ykhackhack for this post:
  • Mohammad6299, Dell_Brett, arshiakh, ting tsai huang, jcbv, oanm2000, simanta, Andrew seah, cybermad, mecheil.edwar, nickycruz, kneth, oreslaw, mohcivil, andyspak2, Vincwilson, bigone, melekeen, techno, chenamoy, abdulazizk, promo8
RAM Structural System V8i x64 Beta 1
(Version: 14.07.00.00 Date: 11/7/2014 )
setup file only
32 bit ,FileSize: 136.94 MB
64 bit ,FileSize: 172.56 MB)
[-] The following 6 users say Thank You to bigone for this post:
  • haze, oanm2000, TAFATNEB, Mohammad6299, JOGAR71, oreslaw
(Version: 14.07.00.05 Date: 2/20/2015 FileSize: 141.87 MB)
setup file only
[-] The following 3 users say Thank You to bigone for this post:
  • TAFATNEB, oanm2000, zrilek
Bentley RAM Structural System V8i (SELECTSeries 7) 14.07.01.01 | 321.7 mb
[Image: 49442613120641001577.jpeg]
Bentley Systems Incorporated, the leading company dedicated to providing comprehensive software solutions for sustaining infrastructure, has released the V8i (SELECTSeries 7) version 14.07.01.01 of RAM Structural System, is the only fully integrated engineering software with complete building analysis, design, and drafting for BOTH steel and concrete structures.
- RAM Structural System allows for the analysis and design of a building using a single model. The entire structure can be modeled, including decks, slabs, slab edges and openings, beams, columns, walls, braces, spread and continuous footings, and pile caps. This full structural model increases designer confidence and creates an efficient environment when dealing with changes.
- The RAM Structural System increases productivity by performing the tedious and time-consuming functions specific to the design of a building such as calculation of live load reductions and lateral load calculations for wind and seismic. In addition, designs are optimized for both concrete and steel.
- Your competitive advantage is realized with the thorough documentation. RAM Structural System automatically provides steel material takeoffs and detailed and summary reports of design calculations and drawings. And for BIM, RAM Structural System offers bidirectional integration with CADstudio and Bentley’s Structural Modeler, Structural Documentation Center, and Autodesk's Revit Structure.
Used by thousands of design firms, steel fabricators, and educators, from one-person firms to some of the largest E&C companies in the world, the RAM Structural System is helping to redefine how engineers work.
RAM Structural System V8i Release 14.07 New Features and Enhancements:
[-] The following 11 users say Thank You to TAFATNEB for this post:
  • zrilek, araza023, LIUKANADA, oanm2000, bridgeengineer, bigone, ykhackhack, ting tsai huang, Hengki, nyungaw, caifan
