Bentley PowerSurvey V8i (SELECTSeries 3) 08.11.09.493
[Image: 96852749237035115667.jpg]
[Image: 57888310181477912873.jpg]
PowerSurvey is a comprehensive survey data management solution. It provides surveying professionals with a complete set of survey-specific tools for both InRoads and GEOPAK. Built on MicroStation PowerDraft, the software directly processes the data from your field survey device and automatically displays the resulting graphics onscreen. You can then manipulate the data using PowerSurvey's editing, reduction, and adjustment tools.
- Data Collector Support
PowerSurvey communicates with all industry-leading data collectors. Connect your data collector directly to a personal computer, laptop, or tablet PC and use PowerSurvey to manage the survey data. PowerSurvey can also upload GEOPAK or InRoads data to the data collector for field stakeout procedures.
- Customizable Feature-Driven Processing
PowerSurvey supports extensive feature databases that detail the representation of each survey shot or feature — including symbolization, labeling, DTM control, and more. The feature database is completely user-definable and ensures standardization from the field surveyor to designer. As you process data, the software draws points and features in accordance with the feature table specified. With this powerful capability, you can generate drawings onsite —immediately after the survey has been collected — for in-field verification.
- Survey Data Adjustments
Editing and adjusting your survey data is an intuitive process when you use PowerSurvey. The software employs industry-standard routines to quickly make geometry adjustments and finalize your data. PowerSurvey offers least squares, compass rule, and transit rule adjustments. You can visually inspect the adjusted data and complete the topographic drawing in both DGN and DWG formats. The data can then be shared with the members of the project team that are using either GEOPAK or InRoads.
- Interactive Coordinate Geometry
Bentley PowerSurvey includes integrated coordinate geometry (COGO) tools. This valuable toolset enables you to perform offset commands, intersections, traverse, and many other geometry commands. Additionally, you can leverage the data generated with other modules of the InRoads and GEOPAK families of products.
  • Dell_Brett, joker™, ykhackhack, oanm2000, josephwsl, malc, chaplin, Mohammad6299, cenlara
Bentley PowerSurvey V8i (SELECTSeries 3) 08.11.09.674
[Image: comments.png]
[-] The following 1 user says Thank You to Mohammad6299 for this post:
  • Dell_Brett
Bentley STAAD.Pro V8i (SELECTSeries 6) 20.07.11.70 RajaK 4 8,778 06-08-2017, 11:29 AM
Last Post: bigone
Bentley AECOsim Building Designer V8i (SELECTSeries 3) 08.11.09.376 BennyP 1 3,642 05-15-2017, 09:12 AM
Last Post: wisamnn
Bentley SewerGEMS V8i (SELECTSeries 4) 08.11.04.54 emmi 2 3,751 12-23-2016, 05:29 AM
Last Post: balimela
Bentley PowerCivil V8i (SELECTSeries 2) 08.11.07.614 BennyP 1 3,476 12-13-2016, 08:15 PM
Last Post: oanm2000
Bentley gINT Pro Plus V8i (SELECTSeries 1) 08.30.03.223 cace-01 2 4,476 02-09-2016, 11:24 AM
Last Post: PinkPant
