Install CivilEA Toolbar
Advertisements:
Contact us for Ads About Civil.com
Eagle Point 2009 Q2 9.2.0
Current time: 02-07-2012, 05:19 AM
User(s) browsing this thread: 1 Guest(s)
Author: BennyP
Last Post: Inge05
Vote on Google+:
Post Reply
10-03-2009, 09:41 AM (This post was last modified: 11-17-2009 05:46 PM by BennyP. Edit Reason: )  (Print Post)
Post: #1
Intersection Design
Intersection Design helps automate the entire design process from pavement, island and median design to curb, shoulder and sidewalk layout, and finishing with analyzing the design and calculating intersection quantities.
Profiles
Using Profiles, you can create a profile of the natural or proposed ground and place that profile into your drawing. It also provides you the tools to draft in tangents, vertical curves, manholes, pipes, headwalls, flared end sections and wingwalls. Annotation and querying tools are also provided to help produce finished drawings.
Quantity Takeoff
Quantity Takeoff reduces the time spent counting and measuring items within a project, giving you more time to analyze projects and their costs.
RoadCalc™
Considered an industry standard for complex roadway projects, RoadCalc™ is also a valuable tool for other corridor-based projects such as subdivision streets, berms, ditches, canals, dams, runways and taxiways.
Site Design
Site Design is a toolkit for situations when your project requires complex site modeling and analysis. Slopes, drainage patterns and earthwork volumes can be analyzed for any type of site, including parking lots, detention ponds, landfills, building complexes and subdivisions.
Surface Modeling
The primary function of Surface Modeling is the ability to create and edit three-dimensional models of the ground surface and then automatically represent these models as contour maps. Not only does it reduce the amount of time needed to generate a topographic map of original ground survey points and line work, it also aids in the modeling of proposed designs.
SYSTEM REQUIREMENTS
Surveying, Civil Design, Hydraulic & Hydrology, and Landscape and Irrigation Design Solutions
Intel Pentium-based processor (1.7 GHz or faster)
Microsoft Windows NT, 2000, Windows XP (Home or Professional) or Vista (Basic, Premium, Ultimate, Business, Enterprise)
512 MB of RAM (1 GB+ recommended)
200 MB free hard drive space prior to installation (+55 MB if installing on-line manuals)
800 X 600 VGA video display (1024 X 768 recommended)
A mouse or digitizer device compatible with Windows
CD-ROM drive (for initial installation only)
One, two, or three of the following CAD systems:
AutoCAD 2000, 2000i, 2002, 2004, 2005, 2006, 2007, 2008, 2009, 2010
AutoCAD Civil 3D 2008, Civil 3D 2009, Civil 3D 2010
Autodesk Map 4/2000, 2000i, 5, 6, 2004, 3D 2005, 3D 2006, 3D 2007, 3D 2008, 3D 2009, 3D 2010
Autodesk Land-Enabled Desktop 2, 3
MicroStation SE, J, V8, XM, V8i
BricsCad 5.1, 5.2, 6.0, 6.1, 6.2, 7.0, 7.1
screenshots:
[Image: ut8v2486o49vujlk4vv2.gif]
Download Links:
Original links
Links changed and alive.
Password:
Upload by giovas
Tried some different cracks but the included activate all products.
Find all posts by this user
Quote this message in a reply Add Thank/Agree You
[-] The following 30 users say Thanks/Agree You to BennyP for this post:
kowheng, kowheng, YaqubMughal, YaqubMughal, timosi™, timosi™, Chillpill, Chillpill, haze, haze, meditation, meditation, zrilek, zrilek, oanm2000, oanm2000, 3d Modeller, 3d Modeller, freestar, freestar, osurv, Dell Brett, snakes, beta, thanzawtun, jopeji, fatjon87, Muhammad Adnan, spat, pepape
10-14-2009, 04:34 AM  (Print Post)
Post: #2
RE: Eagle Point 2009 Q2 9.2.0
(10-13-2009 11:48 PM)muzoben Wrote:  no link
New links:
[-] The following 9 users say Thanks/Agree You to giovas for this post:
timosi™, timosi™, zrilek, zrilek, Amobin, lanz, vangjo, pepape, spat
12-11-2009, 09:20 AM  (Print Post)
Post: #3
Can you please put only the crack???
[-] The following 1 user says Thanks/Agree You to Inge05 for this post:
saqib2s
Post Reply
