Statics and Mechanics of Structures
Author: Krenk, Steen, Høgsberg, Jan | Size: 9.92 MB | Format: PDF | Quality: Original preprint | Publisher: Springer | Year: 2013 | pages: 506 | ISBN: 9789400761131
[Image: 10469306037466658258.jpg]
The statics and mechanics of structures form a core aspect of civil engineering. This book provides an introduction to the subject, starting from classic hand-calculation types of analysis and gradually advancing to a systematic form suitable for computer implementation. It starts with statically determinate structures in the form of trusses, beams and frames. Instability is discussed in the form of the column problem - both the ideal column and the imperfect column used in actual column design. The theory of statically indeterminate structures is then introduced, and the force and deformation methods are explained and illustrated. An important aspect of the book’s approach is the systematic development of the theory in a form suitable for computer implementation using finite elements. This development is supported by two small computer programs, MiniTruss and MiniFrame, which permit static analysis of trusses and frames, as well as linearized stability analysis. The book’s final section presents related strength of materials subjects in greater detail; these include stress and strain, failure criteria, and normal and shear stresses in general beam flexure and in beam torsion.
[-] The following 24 users say Thank You to ir_71 for this post:
  • apocalipse, warbeast, vardan, Jackass, cace-01, seriousboy, red_pool61, yanburak, ingchio, gulilero, pezhmankhan, Dell_Brett, harsono, ibg0203, Andrew seah, kowheng, malc, Quantumm, TurboXUser, asim99, peixoto, chairatpk, zrilek, oanm2000
[-] The following 5 users say Thank You to pezhmankhan for this post:
  • blaze, betinnn, cristi, asim99, zrilek
new links - 7.7MB pdf
[-] The following 17 users say Thank You to r3be1 for this post:
  • Quantumm, slowet, Mohammad6299, dinu69in, Albert, Dell_Brett, subin91, simanta, draluka, eliseo.as, oanm2000, ruaumoko, PinkPant, bridgeengineer, cristi, emmi, harsono
Links above not working
[-] The following 14 users say Thank You to konstobo for this post:
  • milova, Dell_Brett, cace-01, munycamsec, jcbv, oanm2000, Nita1391, atram, hodzicemir, mgdario, tuanpecc1, simanta, cristi, sodapas
Nonlinear Analysis of Thin-Walled Structures: Statics, Dynamics, and Stability ssobhan 0 1,346 07-25-2014, 09:15 PM
Last Post: ssobhan
