CSI SAP2000 v15.2.1
Current time: 12-16-2018, 10:44 PM
Author: warbeast
Replies 6
Views 9465
CSI SAP2000 v15.2.1
CSI SAP2000 v15.2.1
[Image: 63214373431176880461.png]
SAP2000 V15.2.0 and V15.2.1 Enhancements
- The memory capacity has been increased for the graphical user interface, allowing larger models to be handled.
- The analysis of certain non‐symmetrical frame sections now accounts for coupled bending due to the product of inertia, I23, and for the coupling between major shear (V2) and torsion when the shear center is not located at the centroid of the section. Steel frame design and cold‐formed frame design are not affected except as may due to changes in analysis results. Steel frame design was already accounting for the rotated principal axes of bending for angle sections as documented for the various codes.
- The number of time steps that can be run in a single linear or nonlinear (FNA) modal time‐history load case has been increased for cases with a large number of link elements.
- Italian material property definitions have been added.
- Steel frame design using the "AS4100‐1998" and "NZS 3404‐1997" codes have been enhanced to provide more design details.
- Mass participation ratios for the rotational acceleration loads (RX, RY,and RZ) have been changed so that they are now reported with respect to the centroid of the structure. Previously they were reported with respect to the global origin.
- The import of StruCAD*3D models has been enhanced to allow the import of the Cb, Cm, and unbraced‐length design overwrites.
[Image: comments.png]
Use your brain...
StandAlone Installation:
[-] The following 12 users say Thank You to pezhmankhan for this post:
  • amareen2000, rezart, jcbv, mowafi3m, blaze, gampang_ingat, MOSS2000, zrilek, eRw1n, haze, bigone, fbx_rdnk
Use your brain...
[-] The following 20 users say Thank You to warbeast for this post:
  • stosto6666, vladmihai, slowet, ssi3k, wesam_19701970, mowafi3m, zrilek, Andrew seah, mgdario, narendra, MOSS2000, 1975JACC21, rezart, devilmaycry, eRw1n, jcbv, haze, bigone, Rami11, chenamoy
CSI SAP2000 15.2.1 Ultimate
623.1 mb
[-] The following 21 users say Thank You to Dell_Brett for this post:
  • jcbv, blaze, gacella, Diquan, rezart, ssobhan, seriousboy, joker™, herea, zrilek, Rainbow, malc, Andrew seah, haze, engiman27, bigone, golpesar, falconado, arceon, stosto6666, cristi
Password for Uploadboy link:
[-] The following 2 users say Thank You to pezhmankhan for this post:
  • haze, bigone
Please note that, link posted by Dell Bret is a Chinese version (Language) of SAP2000 15.2.1 Ultimate.
Maybe you need to read the Private Note in post #1
  • Dell_Brett
