Evaluation of Rainfall Networks Using Entropy - by P F Krstanovic
Current time: 06-21-2018, 06:51 PM
Author: asim99
Last Post: arshiakh
Replies 3
Views 1575
Evaluation of Rainfall Networks Using Entropy: I. Theoretical Development
Author: P. F. KRSTANOVIC, | Size: 760 KB | Format: PDF | Quality: Unspecified | Publisher: Springer | Year: 1992 | pages: 15
This paper, the first in a series of two, develops an entropy-based approach for evaluating
rainfall networks. Space and time dependencies between raingages are examined by autocovariance
and cross-covariance matrices. Multivariate distributions, associated with different dependencies, are
obtained using the principle of maximum entropy (POME). Formulas for entropy (uncertainty in data
of one raingage), joint entropy (uncertainty in data of two or more raingages) and transinformation
(common information content among two or more raingages) are derived for each distribution, based
on normal data. The decision whether to keep or eliminate a raingage depends entirely on reduction
or gain of information at that raingage. The lines of equal information (isoinformation contours are
defined by considering two raingages (bivariate case) and many raingages (multivariate case).
a- Follow the Forum Rules.
[-] The following 2 users say Thank You to asim99 for this post:
  • ska51, kowheng
Evaluation of Rainfall Networks Using Entropy: II. Application
Author: P. F. KRSTANOVIC | Size: 938 KB | Format: PDF | Quality: Unspecified | Publisher: Springer | Year: 1992 | pages: 20
This paper, the second in the series, applies the entropy approach to space and time evaluation
of rainfall networks in Louisiana. The evaluation is made for five sampling intervals: daily, 2-day,
weekly, monthly, and yearly, and for two separate seasons. In each case, the best combination of raingages
is suggested and the lines of equal information (isoinformation contours) are constructed showing the
areas of greater or less information transfer. The isoinformation lines are especially suitable in decisions
concerning the expansion of the existing network or deleting the unnecessary raingages.
  • ska51, kowheng
Evaluation of rainfall networks using entropy: I. Theoretical development
Author: P. F. Krstanovic; V. P. Singh | Size: 761 KB | Format: PDF | Quality: Unspecified | Publisher: Water Resources Management(Springer) | Year: 1992 | pages: 279-293 | ISBN: --
This paper, the first in a series of two, develops an entropy-based approach for evaluating rainfall networks. Space and time dependencies between raingages are examined by autocovariance and cross-covariance matrices. Multivariate distributions, associated with different dependencies, are obtained using the principle of maximum entropy (POME). Formulas for entropy (uncertainty in data of one raingage), joint entropy (uncertainty in data of two or more raingages) and transinformation (common information content among two or more raingages) are derived for each distribution, based on normal data. The decision whether to keep or eliminate a raingage depends entirely on reduction or gain of information at that raingage. The lines of equal information (isoinformation contours) are defined by considering two raingages (bivariate case) and many raingages (multivariate case).
Evaluation of rainfall networks using entropy: II. Application
Author: P. F. Krstanovic; V. P. Singh | Size: 938 KB | Format: PDF | Quality: Unspecified | Publisher: Water Resources Management(Springer) | Year: 1992 | pages: 295-314 | ISBN: --
This paper, the second in the series, applies the entropy approach to space and time evaluation of rainfall networks in Louisiana. The evaluation is made for five sampling intervals: daily, 2-day, weekly, monthly, and yearly, and for two separate seasons. In each case, the best combination of raingages is suggested and the lines of equal information (isoinformation contours) are constructed showing the areas of greater or less information transfer. The isoinformation lines are especially suitable in decisions concerning the expansion of the existing network or deleting the unnecessary raingages.
Spatial rainfall estimation by linear and non-linear co-kriging of radar-rainfall and arshiakh 0 939 04-08-2013, 07:06 PM
Last Post: arshiakh
