COMPRESSION TESTS OF SHORT WELDED I-SECTIONS
Current time: 12-12-2018, 10:16 AM
Author: asim99
Last Post: asim99
Replies 0
Views 1015
Author: Andrew J. Davids and Gregory J. Hancock | Size: 1 MB | Format: PDF | Quality: Unspecified | Publisher: ASCE | Year: 1986 | pages: 17
The local buckling and post-local buckling behavior of short length
I-section columns fabricated by welding high tensile steel plate is described. Six
sections of three different section geometries were tested to destruction by loading
between rigid end plattens mounted on freely rotating bearings in a
compression testing machine. Accurate measurements of welding residual strains
and geometric imperfections were taken prior to testing and are presented in
the paper. Comparisons of the test local buckling loads are made with a finite
strip buckling analysis including welding residual strain. Comparisons of the
measured axial stiffnesses and stress distributions were made with a nonlinear
finite strip analysis, which includes geometric imperfections and welding residual
strain. The test loads are compared with those based on the Winter effective
width formulas.
a- Follow the Forum Rules.
[-] The following 6 users say Thank You to asim99 for this post:
  • jcbv, mastermind, malc, kowheng, andersen3, Dell_Brett
Column Tests of Cold-Formed Steel Non-Symmetric Lipped Angle Sections darkdkay 3 2,456 04-09-2013, 09:17 AM
COMPRESSION TESTS OF LONG WELDED I-SECTION COLUMNS asim99 0 1,075 04-03-2013, 02:17 PM
Last Post: asim99
