CSI SAP2000 14.2.5
Current time: 01-23-2018, 06:34 PM
Author: atram
Last Post: LiviuM
Replies 1
Views 3634
CSI SAP2000 14.2.5
CSI SAP2000 14.2.5
[Image: 19349379530962136805.jpg]
The SAP name has been synonymous with state-of-the-art analytical methods since its introduction over 30 years ago. SAP2000 follows in the same tradition featuring a very sophisticated, intuitive and versatile user interface powered by an unmatched analysis engine and design tools for engineers working on transportation, industrial, public works, sports, and other facilities.
From its 3D object based graphical modeling environment to the wide variety of analysis and design options completely integrated across one powerful user interface, SAP2000 has proven to be the most integrated, productive and practical general purpose structural program on the market today. This intuitive interface allows you to create structural models rapidly and intuitively without long learning curve delays. Now you can harness the power of SAP2000 for all of your analysis and design tasks, including small day-to-day problems. Complex Models can be generated and meshed with powerful built in templates. Integrated design code features can automatically generate wind, wave, bridge, and seismic loads with comprehensive automatic steel and concrete design code checks per US, Canadian and international design standards.
Advanced analytical techniques allow for step-by-step large deformation analysis, Eigen and Ritz analyses based on stiffness of nonlinear cases, catenary cable analysis, material nonlinear analysis with fiber hinges, multi-layered nonlinear shell element, buckling analysis, progressive collapse analysis, energy methods for drift control, velocity-dependent dampers, base isolators, support plasticity and nonlinear segmental construction analysis. Nonlinear analyses can be static and/or time history, with options for FNA nonlinear time history dynamic analysis and direct integration.
From a simple small 2D static frame analysis to a large complex 3D nonlinear dynamic analysis, SAP2000 is the easiest, most productive solution for your structural analysis and design needs.
[Image: homepage.png]
[-] The following 6 users say Thank You to atram for this post:
  • Diquan, rezart, red_pool61, faros3000, blaze, LiviuM
Release notes and read me for those too lazy to download and check this version SAP2000 14.2.5:
Pass:
SAP2000 Version 14.2.5 Release Notes Wrote:Note that all Incidents listed below (as well as others) have also been resolved in either SAP2000 v15.0.0 or CSiBridge v15.1.0 or both, as applicable. We recommend that you upgrade to SAP2000 v15.0.0 and/or CSiBridge v15.1.0 at your earliest convenience.
I guess this version is restricted to some clients or markets, or never officially released. They clearly state you should upgrade to version 15, version 14 is discontinued and still has unfixed incidents.
About this version you'll find more information here:
[-] The following 4 users say Thank You to LiviuM for this post:
  • andersen3, rezart, 3fan, jjingo
