Hysteretic energy response of steel moment-resisting frames with vertical mass irregu
Hysteretic energy response of steel moment-resisting frames with vertical mass irregularities
Author: BYONG JEONG CHOI | Size: 362 KB | Format: PDF | Quality: Unspecified | Publisher: BYONG JEONG CHOI | Year: 2004 | pages: 23
[Image: 45788426346267157899.jpg]
Dynamic analyses were carried out to study the seismic response of high-rise steel moment-resisting frames in
16-storey buildings. The frames are intentionally designed using three different design procedures: strengthcontrolled
design, strong column–weak beam controlled design, and drift-controlled design. The seismic performances
of the so-designed frames with vertical mass irregularities were discussed in view of drift ratio, plastic
hinge rotation, hysteretic energy input and stress demand. A demand curve of hysteretic energy inputs was also
presented with two earthquake levels in peak ground accelerations for a future design application.
a- Follow the Forum Rules.
[-] The following 5 users say Thank You to asim99 for this post:
  • kowheng, ting tsai huang, malc, blaze, Dell_Brett
Evaluation of Egyptian code provisions for seismic design of moment-resisting-frame m TAFATNEB 0 1,442 09-05-2014, 03:03 PM
Estimation of hysteretic energy demand using concepts of modal pushover analysis TAFATNEB 0 1,207 08-10-2014, 03:52 PM
Evaluation of the seismic performance of a three-story ordinary moment-resisting conc TAFATNEB 0 1,115 04-26-2014, 07:25 PM
Seismic response of steel frames containing hierarchical frictiondissipating joints TAFATNEB 1 1,630 11-28-2013, 01:08 PM
Self-centering post-tensioned energy dissipating (PTED) steel frames for seismic regi arshiakh 1 1,625 07-21-2013, 12:27 AM
Last Post: Jackass
