RAM Concept V8i 5.0.1 SELECTSeries 7
[Image: 32826255163848962478.jpg]
Version: 05.00.01.04 Date: 10/12/2012
RAM Concept is an analysis and design program that uses
the finite element method for elevated concrete floor
systems, or mat foundations. The floors or mats can be
post-tensioned concrete (PT), reinforced concrete (RC), or
hybrid (a mixture of PT and RC). Concept is extremely
powerful and allows you to design an entire floor in one
model, or design individual strips or beams.
In this context, the term “design” means that:
• The user defines the following: structural geometry,
loads, load combinations, and post-tensioning layout (if
applicable).
• Concept calculates (for any number of load combinations):
the required amount of reinforcement for flexure
and one-way shear according to relevant code requirements;
the stud shear reinforcement (SSR) for punching
shear, stresses for flexure, and deflections.
[Image: comments.png]
[-] The following 11 users say Thank You to BennyP for this post:
  • cordoba123, Dell_Brett, kowheng, StaadEng, bigone, mohcivil, maad59, joker™, pedrozarth, pjcivil, Vincwilson
Mirror RAM Concept V8i 5.0.1 SELECTSeries 7 - Size: 148.26 MB (Install File)
No limits to creativity
[-] The following 5 users say Thank You to joker™ for this post:
  • oreslaw, Rami11, bigone, blaze, Visitante
[-] The following 4 users say Thank You to joker™ for this post:
  • oanm2000, Dell_Brett, samsaid, bigone
RAM Concept V8i
(Version: 05.00.02.12 Date: 2/12/2013 FileSize: 148.37 MB)
[-] The following 7 users say Thank You to joker™ for this post:
  • Arigato, erthqkengnr™, thanhthan, samsaid, chenamoy, bigone, Dell_Brett
RAM Concept V8i
(Version: 05.01.01.10 Date: 2/4/2014 FileSize: 220.85 MB)
RAM Concept V8i SELECTseries 8, r5.1.1, Release Notes
Release Date: February 4, 2014
Installation Instructions:
RAM Concept V8i Release 5.1.1 can be installed side-by-side with previous release versions of Concept. There is no need to uninstall previous release versions.
Error Corrections in RAM Concept V8i Release 5.1.1
RAM Concept V8i Release 5.1.1 is a patch, containing error corrections and minor enhancements. Each issue addressed is summarized below.
Audit Design Section
When the user attempted to audit a cross section generated by a design section, an error with the message “Program Error (Report Parsing Error: bad master node contents)” resulted.
Large Calc Log
RAM Concept became unresponsive when the calc log had a large amount of output.
DXF Import
The import of a dxf file with missing xrefs into RAM Concept caused a program crash in specific and rare instances.
ASCE 7-10 Wind Import
When working with lateral loads that were imported from RAM Structural System, RAM Concept always treated wind loads as service loads, even when they might be ultimate level loads.
Pre-Concept V8i Release 5.1 File Compatibility Warning:
RAM Concept V8i Release 5.1 can read all previous file formats, but writes files in a format that cannot be read by previous versions.
32 bit
64 bit
[-] The following 11 users say Thank You to bigone for this post:
  • Dell_Brett, blaze, zrilek, olgabehe, toa011, oanm2000, bridgeengineer, StaadEng, Rami11, oreslaw, yutt
Bentley.RAM.Concept.V8i.SS9.v05.02.00.21.x86.x64
RAM Concept 5.2 Release Notes
32 bit
64bit
LAVteam crack attached
.rar   patch.rar (Size: 2.15 MB / Downloads: 293)
RAM Concept V8i v05.02.01.10
[Image: 56178539487228040588.png]
32 bit
size 215.6 MB
attached
.rar   LAVTeam patch.rar (Size: 2.15 MB / Downloads: 81)
[-] The following 4 users say Thank You to bigone for this post:
  • oanm2000, Williams, karthikeyans3d, Rami11
64 bit
[-] The following 8 users say Thank You to bigone for this post:
  • ASEC, zrilek, oanm2000, Williams, Rami11, PinkPant, monter, hawking
Bentley RAM Concept V8i SS9 05.02.01.10 build 02/04/2015
(x86 & x64)
[-] The following 21 users say Thank You to joker™ for this post:
  • raja, oanm2000, amindoxiti, Andrew seah, Dell_Brett, malc, subin91, PinkPant, TAFATNEB, ykhackhack, blaze, viet2010, Diquan, pedrozarth, bao2004, Arigato, ralarcon, araza023, krishna22045, deltalead, er.shyams
Bentley RAM Concept Release 3.3 (SELECTseries 3) BennyP 0 2,662 03-26-2010, 10:16 AM
